Wink What I did tonight, Fun hah
Parts for my 83/944
Manifold Gaskets
944-110-163-05-M17
Oil Cap Seal
999-701-653-40-M17
Oil Separator/Filler to Engine Lower
999-701-661-40-M17
Breather Hose from Oil Separator
944-107-187-01-M100
Oil Separator/Filler to Engine, Upper
999-701-613-40-M104
Should I do the Idle Control Valve Hoses? If so where at would those be located exactly? Not sure where im missing the location at. Lol
Removed the Air Box
Removed Fuel Rail and Intake Manifold
Finally got to the AOS - Air oil Separator and removed it
Old 03-17-2013, 10:38 PM
So I cleaned her up first
Then I shall continue to install them back on. But now I need to get some O-Rings and unsure which is which and hoses/lines/etc.
Parts needed.
Upper AOS O-Ring and Lower AOS O-Ring
The Hose that runs from the AOS to the Intake. I want to replace ALL HOSES AND VACUUM LINES/ETC.
O-Rings
This broke b.t.w. *Just a Normal Vacuum line with a splitter?*
Cap O-Ring
A Hose i wanna Replace - Caked in Oil and super Brittle
Old 03-17-2013, 10:45 PM
Everything - Don't even ask why I have so many Pots n Pans - LMFAO
My Working Conditions Lol
Oh and the other Project which parts are on order:
Old 03-17-2013, 10:46 PM
AFM #725
Gawernator's Avatar
Oh, early model no ICV
Watchdog Armory Racing AFM #725 Thanks to my 2017 Sponsors: JPH Suspension | AXO | Armour Bodies | BELL Helmets | Braven | EVLUTION Nutrition | Forcefield Armor | FunTrackDayz | Galfer | Motion Pro | MOTUL | Matrix Racing Concepts | ODI Grips | OGIO | Shorai Inc. | SPEEDMOB | Vortex | Woodcraft | Wicked Audio
http://www.gawerracing.com
Old 03-17-2013, 11:23 PM
Lol
So. Suggestions on anything I should replace while Im in there besides the o-rings/etc.?
Old 03-17-2013, 11:46 PM
AFM #725
Gawernator's Avatar
Vacuum lines, fuel hoses
Old 03-18-2013, 12:07 AM
Hoses. I'll check those in the morning.
Ignore my PM lol
I thought you meant the Hard Lines. Lmfao
Old 03-18-2013, 12:16 AM
AKCJ's Avatar
Thanks for posting. I need to do this too.
Red 83 944
Old 03-18-2013, 12:06 PM
Your welcome
Im replacing all Vac Lines/Hoses/Fuel Lines/Checking all Ground wires for good connections, cleaning up, got the alternator checked *Might as well* its two bolts so you know if its good or okay or like new.
Old 03-18-2013, 04:47 PM
AFM #725
Gawernator's Avatar
Looks like your car has been resprayed from its original color?
Old 03-18-2013, 05:07 PM
Re-Pained, needs body work/Driver front fender and nose panel is dented on left side. Hood is Dented in middle.
We Sprayed it down to make it look decent.
Other then that, Im Spraying down the Motor. Lmao
Old 03-18-2013, 05:13 PM
Volhv's Avatar
How many miles on that thing?
Honestly, unless it's been done... do everything
Stick your finger in the back side of the balance shaft housing. If you can move the plug.... you need a new o-ring.
Has the head been off before? If not, might as well change the headgasket. It's a perfect opportunity to replace valve stem seals, regrind the valves, reseal the camtower, and check for bad lifters. You probably don't want to hear this, but I was in the same position last year, and had to take it all apart again several times when a new thing popped up.
1986 944 NA Sapphire Metallic
http://944porsche.blogspot.ca/
Old 03-19-2013, 08:09 AM
