uvachief
uvachief's Avatar
Send a message via Yahoo to uvachief
Failed ball joint - replace with steel control arm?
My ball joint has failed on my driver's control arm. I replaced the passenger control arm in 2010. I was thinking of trying one of the rebuild kits but I see that 944online sells these steel control arms. Are these an upgrade or a downgrade?
944online.com - Find Parts For Your Porsche 944 And Get Your Car Back On The Road.
Sincerely,
uvachief
1986 944 NA Red 5SPD
Old 03-20-2013, 01:46 PM
AFM #725
Gawernator's Avatar
Is your car really low?
Watchdog Armory Racing AFM #725 Thanks to my 2017 Sponsors: JPH Suspension | AXO | Armour Bodies | BELL Helmets | Braven | EVLUTION Nutrition | Forcefield Armor | FunTrackDayz | Galfer | Motion Pro | MOTUL | Matrix Racing Concepts | ODI Grips | OGIO | Shorai Inc. | SPEEDMOB | Vortex | Woodcraft | Wicked Audio
http://www.gawerracing.com
Old 03-20-2013, 01:58 PM
uvachief
uvachief's Avatar
It is not. Stock suspension.
Sincerely,
uvachief
Old 03-20-2013, 02:05 PM
FransB85's Avatar
it's hard to say up or down on this -grade business. supposedly, these control arms allow a bit more flex than the aluminium ones. However, I think under normal driving circumstances this difference resides between the ears of the beholder, so to speak.
The reason to switch over to these is a cost issue (though some racers like to seam weld these babies, which makes them just as stiff and more durable than alu). If you have damaged your alu control arm beyond repair, you can easily swap the alu ones out for a brand new pair of these vw-based (thus common and cheap) control arms for less than the price of a single aluminium control arm.
If it is only about the ball joints, you can just order a rebuild kit for your control arms, for even less money. The condition is that the ball has not eaten into the aluminium, since this is a pretty unfair match in favour of the hardened steel ball, rendering your arm useless/non-rebuildable.
I have performed this rebuild myself recently and it has been one of the more satisfying projects. I would suggest replacing both at the same time (save one alignment, peace of mind, etc) since you get a set of two anyway.
The set sold on the internet contains ball joint bearings/cups of a superior bronze-alloy that supposedly last the lifetime of the car (YMMV) as well as all the other hardware, as you have no doubt seen already.
So have a look at the ball joint housing and choose.
PS, this is also a good time to replace bushes/caster blocks if they have no been renewed.
Old 03-20-2013, 02:08 PM
Mein Gott!
Panzer909's Avatar
It's a judgement call. I looked into this years ago when my balljoints were shot and needed replaced. The only real advantage to these is $$$ savings over the long haul as the balljoints alone are replaceable. Otherwise, they're heavy as hell with marginal upfront savings.
Johnny
1987 944S
1984 944 (R.I.P.)
1972 Triumph TR6 - 100% trouble free between breakdowns
2003 BMW 325xi
Old 03-20-2013, 04:15 PM
uvachief
uvachief's Avatar
i think i will go with a rebuilt control arm and core charge. thanks.
Sincerely,
uvachief
Old 03-20-2013, 07:41 PM
Volhv's Avatar
I haven't performed the swap to steel arms yet, but I have gathered all the parts....
From Pelican:
x2 steel control arms $45.00
x2 oem control arm front bushing $9.50
x2 balljoint and hardware $30.50
x2 outer sway bar bushings $5.00
x2 Weltmeister control arm rear bushing $17.98
Sway bar brackets and rear mount bracket I got for $40.00 from the local wrecker.
The grand total is just under $150. That will get you one and a half aluminum caster block......
Getting it from the site you listed would cost an extra $250..... chump change.
1986 944 NA Sapphire Metallic
http://944porsche.blogspot.ca/
Old 03-21-2013, 07:56 AM
White and Nerdy
Tervuren's Avatar
I swapped my '86 over to steel control arms. Honestly - the weight difference isn't that much. Porsche recommends against their aluminum arms in racing applications on the early cars due to potential for stresses from the casting process to show up, resulting in control arm failure.
In this case, I'd go which ever way is cheaper/easier.
Old 03-21-2013, 08:17 AM
9FF 9FF is offline
9FF's Avatar
I use boxed steel on my track cars and alu for the street cars. Both work as advertised without issues.
The alu is stronger, can use the better 968 castor blocks and doesn't give at the sway bar mount even with 968 30mm bars. The steel is better if you have an "off" as it will bend instead of fracture. Also it's a cheaper track option which is always good.
...Porsche recommends against their aluminum arms in racing applications on the early cars due to potential for stresses from the casting process to show up, resulting in control arm failure...
Never heard this before. Can you post up the tech bulletin.
...I wish they still made those Charile arms from a few years back, billet, light, easy ball joint swap and virtually indestructible.
Old 03-21-2013, 08:41 AM
Have a look at paragon if you decide to buy the steel arms, prices are good and if you want a stiffer setup than stock they offer this:
Porsche 924S and 944 Control Arm Set with Race Bushings
Old 03-21-2013, 08:42 AM
J1NX3D's Avatar
i have a question about the front A arm bushings. I've been collecting new bushings to put in when I go to late offset and it turns out I bought a pair of front A Arm bushings from both All Zims and paragon.
Porsche 944, 944S, 944S2, Turbo and 968 Control Arm Bushing, front of front.
Front Control Arm Pivot Bushing, 944/T/S/S2/968
they are slightly different. the overall dimensions are the same but I am OCD. The ones from paragon have a ribbed surface whereas the Zims ones don't and are painted black.
Are they ok to use together like this pic? or one type per side? or should I just get another pair to match?
'86 944S3 conversion
- '94 968 3.0 engine
- 6 spd/LSD
- 17x8,17x9 Oz Racing Crono wheels
Old 03-21-2013, 12:24 PM
944sracer's Avatar
You could go with Fabcar A-arms. They are steel with spherical ball joints. The A-arm is a massive weak point on these cars so it is not a surprise they broke. The FabCar A-arms are pricey but very nice.
89' 951 Turbo S Race Car - SP-3, PT-B
87' 944 Diamond Blue Metallic - DD
"Practice does not make perfect. Perfect practice makes perfect" - Ross Bentley
Old 03-21-2013, 09:34 PM
AFM #725
Gawernator's Avatar
And there you see how overpriced 944online is. $155 for the control arm PAIR and bushings from Paragon, versus $422 from 944online.
Uh huh.
Old 03-21-2013, 09:48 PM
Catamax944's Avatar
I believe their price is so high because the include the rear mount/clip . Brand new from porsche that mount alone is about 100$ , when i changed to the steel arms i had to buy one of the mounts brand new because i couldn't source a used one in time.
If you convert to steel arms ideally the rear clips/mounts and the sway bar mount should be sourced used because they are way too expensive new.
Catalin
'86 DD
Old 03-22-2013, 12:02 PM
AFM #725
Gawernator's Avatar
Subtract $200 it's still way more lol
Old 03-22-2013, 12:06 PM
Banned
While I'm browsing the boards here again I thought I would add;
NEVER BUY FROM 944ONLINE. Ian is a prick and the most unprofessional business owner I have met in a long time. Their prices are unforgivable, the site design looks like something a middle school kid could whack together in a week. Pelican isn't the cheapest by any means either - but the staff here are SO MUCH more professional that id spend money here a hundred times before I would go to 944online.
Full disclosure - Ian offered me parts FOR FREE to try and keep my business after snapping out on me like I was a child or something. I kindly refused and continue to let everyone know exactly what kind of person he is.
Old 03-22-2013, 12:58 PM
Toofah King Bad
Rasta Monsta's Avatar
Wow, that is really tough to imagine.
» 1987 924S - Pro44 Race Car • 1987 924S - Got Boost? «
"DETERMINATION. Sometimes cars test us to make sure we're worthy. Fix it." - alfadoc
Old 03-22-2013, 02:32 PM
White and Nerdy
Tervuren's Avatar
Trust me - you always want a weak point somewhere that goes first, and is cheap. I raced off road RC monster trucks, and if I beefed everything up - it all bent up at once in a huge pile of scrap. With a "break point", I would spend $30 bucks, without one, it could be $600. I ran an altered upper front A-arm from the old skinny style T/E-Maxx to keep my geometry, the plastic part had flex that would keep stuff from breaking, and if I did break it, it was cheap. If I tore a $500 bulkhead and bent a $100 RF suspension from having the entire setup equally strong, it'd not be a good day!
9ff, I can't find it online, I seem to remember it, maybe my mind is playing tricks on me. I'll take a look at my manual this weekend and see if I can find it.
Old 03-22-2013, 02:50 PM
Gawernator, Re-do your math when cost compare as you are way off.
Cheers,
Larry
Retired USAF and Civil Service,
1985.5 NA Graphite Metallic, A never ending work in progress,
1992 968 Horizon Blue Cab "New Toy"
Old 03-23-2013, 04:32 PM
Banned
People literally cannot wait for your foul, insufferable, fat ass to die of diabetes.
You are so full of your own fat greasy Guido self that you use green text. Really? You are that important to yourself you color your text now?
Well color me surprised, I was hoping you had already wrapped your **** car around a telephone pole. Lol.
Old 03-23-2013, 04:50 PM
Tags
a arm , control arm
Copyright ©2000 - 2021, vBulletin Solutions, Inc.
