Info: How to Clean AOS
A suggested procedure for cleaning the air/oil separator is outlines below:
Remove air/oil separator in accordance with the Service Manual.
Flush the air/oil separator with mineral spirits to remove oil.
Utilizing compressed air, remove mineral spirits from air/oil separator.
Place entire air/oil separator in container of Berryman’s Chem-Dip making sure unit is submerged, and all air pockets have been removed from internal surfaces of the air/oil separator.
Soak air/oil separator overnight for best results.
Remove the air/oil separator from the Berryman’s container and rinse with water.
Utilizing compressed air, remove any water from both inside and outside of the
air/oil separator.
Reinstall the air/oil separator
Check for oil leaks and verify proper operation.
Berryman's Container is just the bucket of Chem-Dip "Carb and Parts Cleaner"
The AOS WILL cause buildup on the bottom of it after age. This would help function and proper usage of the AOS.
Just thought I'd share with you guys, since a lot of people say use water....then Seafoam. This is much more effective. Buy some ChemDip and stick it in over night. Flush and it makes the oil easier to get out.
Old 03-21-2013, 01:55 AM
Proprietoristicly Refined
John_AZ's Avatar
Nice. Thanks for the information on cleaning.
Here is a link that may help new owners understand why the AOS may need to be cleaned:
Oil filler/separator is on a 944 - Rennlist Discussion Forums
J_AZ
1988 924S 77K July 2017 ...+ 1987 924S 145K DD (+15K est. bad odometer)
Old 03-21-2013, 04:43 AM
Volhv's Avatar
The top "cap" can also be removed, revealing a now brittle o-ring.
It would also be easier to clean it this way.
1986 944 NA Sapphire Metallic
http://944porsche.blogspot.ca/
Old 03-21-2013, 07:41 AM
'89 944S2
Very timely.
Many thanks
Greg
Old 03-21-2013, 10:39 PM
1983 944 N/A
POPS 83 944's Avatar
What size is the o-ring or is it available from the part side???
"To my family, the 944 is more than a new car. It is a new and true Porsche.
At Porsche, excellence is expected."
Dr. F. Porsche Stuttgart
Old 03-21-2013, 10:53 PM
Volhv's Avatar
The o-ring is not available for purchase. Size is about 80mm OD, and 2.5 mm thickness. The old one can be used to find something that will work.
Old 03-23-2013, 03:44 AM
968 oil separator cap
Does anyone know how to remove the cap to the AOS on a 968?
Old 07-25-2013, 08:29 PM
For anyone that is interested - the o-ring for the cover is an AS568A-151 size. It is available in hi-temp silicone from McMaster-Carr, p/n 9396K172. A pack of 10 costs $8.09.
I bought a pack and have 9 more left. Rather than trying to sell them, I would like to pay them forward to other 944 owners. If you would like one, send me a pm, I'll give you my address, then just send me a SSAE and I'll send you one until I run out.
Old 06-03-2014, 07:58 PM
The question I have is why bother cleaning the AOS?
Old 06-03-2014, 08:02 PM
perhaps to help oil drain better at the bottom?
but there's really nothing at all inside of it. it is just a can with a few holes in it..
Old 06-03-2014, 08:26 PM
Silicone Viton or Nitrile for o-rings
I was curious about the different o-ring materials since there are so many & found Chemical Compatibility Guide. Comparing Silicone and "Motor oils" returns "Good" but common Nitrile (NBR) or Viton (FKM) both come back as excellent. I'm no chemist, just passing along what I find. I thought silicone would be better, maybe not? Am I missing something? Just trying to learn something new.
1988 Silver 924-S Original owner
Porsche 924S: The 944's cheaper, faster little sister.
Old 06-03-2014, 11:02 PM
Porsche Crest Smoke at Start up
Can this cleaning procedure be used on 2001 986 boxster as well?
Old 06-04-2014, 04:43 AM
BUmping this up for the records and future searches...
McMaster-Carr pn# 9396K172 (as mentioned above) is a perfect fit for the 944 AOS. (Unit shown is an S2 AOS)
See attached photo! (You only need one but I wanted to show fitment on both sides)
Old 04-11-2015, 07:59 AM
I've found this website to be really useful. https://trp.co.uk/ffkm/
Plenty of information about O-rings and you can receive a quote off them by calling them up.
Old 09-25-2018, 01:50 AM
GO AWAY! Stay in Cali
Swennydawg's Avatar
The idea of an oil and air separator is to extract the oil from the air before it's sent back to the intake manifold and put it someplace where it won't cause a problem,like the crankcase. If it's goobered up or if the seals fail it'll most likely end up in the intake system. Just a small amount in there will put a frown on your face.It's a mess to clean and needs to be on the same service cycle as the timing/balance shaft belts. Cleaning and changing two seals at a nominal cost and while you're there the dipstick seal. When you start sucking oil,you'll know it!
Old 10-03-2018, 12:12 PM
^^ a little smoky, but your valves have never run quieter/smoother 8-)
Old 10-03-2018, 12:49 PM
I use this website whenever I need to replace any of my existing O-rings: https://www.martins-rubber.co.uk/
This Chemical Compatibility Guide is also a good tool for breaking down the qualities of each type of sealing material for o-rings so you know exactly what you're getting. Hope this helps!
Old 01-30-2019, 07:54 AM
that is what I find in the bottom hole of AOS on my 944
what the heck is that
is there any membrane has to be inside?
Old 06-12-2019, 06:24 PM
theer's Avatar
Tirez is French for "pull", so that's definitely not OEM!
The hole in the middle looks like it was made with a Phillips screwdriver. Could be a top from an oil additive someone was squirting in there and the lid popped off...?
Old 06-13-2019, 08:22 AM
