cold air intakr for my 83 944?
I live in cali. So I HAVE to have a Carb No.
1983 944 N/A
Don't do it, you will lose some hp. Stock box is better and it draws in cold air from the fender area.
"To my family, the 944 is more than a new car. It is a new and true Porsche. At Porsche, excellence is expected." Dr. F. Porsche Stuttgart |
Stock box has a Hole the size of a Golf Ball on the bottom. Tell me how it wouldn't improve it? Any Filter isn't gonna improve it. NORE disprove it. Filter is just a Damn filter |
Andrew Gawers' Dad
Like pops said, there is nothing better than the stock air box. If yours is a piece of ****, then start looking for a used one. You will gain nothing from a cai.
Then mend it, dear Trevor, dear Trevor, dear Trevor
replace it with a good stock airbox from a wrecker. make sure its got the snorkel and the seal to go into the fender. the stock airbox is better than a pod filter. period. you may save weight with a pod filter but thats about it. you will get heatsoak with the pod filter without sealing a new box around it and ducting air to it but then the stock airbox and filter has more surface area than a pod filter so why reinvent the wheel? get a k&n panel filter that fits the stock airbox if thats the kind of thing that gives you jollies.
https://www.instagram.com/kiwi944s3/ '86 944S3 conversion - '94 968 3.0 engine - 6 spd/LSD - 17x8,17x9 Oz Racing Crono wheels Last edited by J1NX3D; 03-19-2013 at 08:51 PM.. |
it makes me crazy when people try to tell you that the stock airbox works better than a cold air intake. it doesn't. this does however assume that you actually have a cold air intake, and not just some cone filter stuck somewhere.
a good cold air intake will give you about 5% more power than the stock airbox of just about any car. there are very few that cannot be improved upon. it will have a cold source of air, and a direct route to the intake. the connecting pipe will be smooth and without obstruction (no ribs etc). the filter will have at least as much surface area as stock. preferably it will have a box around it to maintain a high pressure zone done right, you can get more power. the tradeoff is usually that you gain more noise. that being said, i don't know if anybody has gone to the trouble of getting a CARB certification for anything. i'm also not so sure you need one. |
AFM #725
So basically, you have a cold air intake stock. Ditto on the K&N What is the CARB number for?
Watchdog Armory Racing AFM #725 Thanks to my 2017 Sponsors: JPH Suspension | AXO | Armour Bodies | BELL Helmets | Braven | EVLUTION Nutrition | Forcefield Armor | FunTrackDayz | Galfer | Motion Pro | MOTUL | Matrix Racing Concepts | ODI Grips | OGIO | Shorai Inc. | SPEEDMOB | Vortex | Woodcraft | Wicked Audio http://www.gawerracing.com Last edited by Gawernator; 03-19-2013 at 09:39 PM.. |
1983 944 N/A
![]() What does CARB compliant mean - Ask Community
"To my family, the 944 is more than a new car. It is a new and true Porsche. At Porsche, excellence is expected." Dr. F. Porsche Stuttgart Last edited by POPS 83 944; 03-19-2013 at 10:09 PM.. |
1983 944 N/A
Trevorlw if you need a stock air box I might have one laying around, I can check this weekend for you.
Rogue Tuning
For a 2.5L Non-turbo, it is the best performing solution.
-Joshua www.RogueTuning.com Last edited by Rogue_Ant; 03-19-2013 at 11:00 PM.. |
Filter is a Filter. Like a Oil Filter. I highly doubt an oil filter would add HP.
1983 944 N/A
AFM #725
Haha I know what CARB is (I live here) but I meant why you would need it, Smog shops here must just not care...
Watchdog Armory Racing AFM #725 Thanks to my 2017 Sponsors: JPH Suspension | AXO | Armour Bodies | BELL Helmets | Braven | EVLUTION Nutrition | Forcefield Armor | FunTrackDayz | Galfer | Motion Pro | MOTUL | Matrix Racing Concepts | ODI Grips | OGIO | Shorai Inc. | SPEEDMOB | Vortex | Woodcraft | Wicked Audio http://www.gawerracing.com |
I know RA :-) but some people like the extra noise though. And the k&n stickers.
https://www.instagram.com/kiwi944s3/ '86 944S3 conversion - '94 968 3.0 engine - 6 spd/LSD - 17x8,17x9 Oz Racing Crono wheels |
curtisr
The first clue that the factory snorkel set-up is a good one came to me when I asked for a K & N cold-air system at my favourite auto parts store. They told me that K & N doesn't make one for the 924s, anyways. They do, of course, make a filter to fit the box. [Which, by the way, I found to not fit my 928's air box very well: I had to twist the straps to take up the slack (as it were).]
i'm quite sure i could find power in a cold air intake. in 30 years of doing this, i have never seen a car that could not benefit from one. it's very hard to show it on a dyno, and you have to use an eddy current dyno. you can't use a standard dynojet. you also need a HUGE fan that can make 100mph wind.
due to german sound restrictions, they have to build their airboxes with a that in mind. unfortunately they always cost power. a manometer will show you where the OEM airbox falls down. it's not hard to find the restrictions. some of them can even be calculated. i see why people have a hard time with the OEM airbox, but i also see how it can be done, and i am sure it will work. the problem is that you're going to spend more money that it's probably worth to get the amount of power you would get. i just can't see somebody spending $200+ to get 5hp. Last edited by flash968; 03-20-2013 at 07:06 AM.. |
