AFM #725
Ernie, one size fits all Gl-4/5 and MT-1? .....
Watchdog Armory Racing AFM #725 Thanks to my 2017 Sponsors: JPH Suspension | AXO | Armour Bodies | BELL Helmets | Braven | EVLUTION Nutrition | Forcefield Armor | FunTrackDayz | Galfer | Motion Pro | MOTUL | Matrix Racing Concepts | ODI Grips | OGIO | Shorai Inc. | SPEEDMOB | Vortex | Woodcraft | Wicked Audio http://www.gawerracing.com |
thanx for that, i actually just found redline mt-90 in the west island of Montreal for $35 a quart.
ouch. they also have royal purple for $20 a quart. |
AFM #725
Well if that Valvoline says it meets GL-4, try it out
the royal purple maxgear 75w90 says it also meets gl-4
I read mixed reviews on Royal purple, so ill probably stick to the valvoline, castrol and the redline. |
also, of note, the castrol syntrax data sheet specificlaly mentions Porsche on page 2
http://www.castrol.com/liveassets/bp_internet/castrol/castrol_australia/STAGING/local_assets/downloads/s/Syntrax75W_90_B1278983.pdf |
Toofah King Bad
» 1987 924S - Pro44 Race Car • 1987 924S - Got Boost? « "DETERMINATION. Sometimes cars test us to make sure we're worthy. Fix it." - alfadoc |
Mobile 1 15w-50 is what I prefer, but since I don't want oil leaks everywhere I run VR1 20w-50. My dad mixes V-Twin and the VR1 in his 911s. I have higher oil pressure with the VR1, but that's expected. As for tranny, Redline!!!!! I had the engine out for 9 months a few years ago and when I got it running again it took FOREVER to shift. Push in clutch, move to neutral, give it a couple seconds, put in next gear. Put in Reline and it did a world of difference.
Toofah King Bad
Ok, you are right, running 5w40 synth per 2009 factory recommendations instead of 10w40 dino oil as recommended thirty years ago is definitely going to destroy my engine.
OP, you have my apologies for giving such awful advice.
AFM #725
20w50 woohoo
20w 50..... not sure why this is such a hard thing to understand..... each to there own I guess.
Parrothead member
Been running Castrol GTX 20w50 for over 300,000 miles. I also run 15w 40 diesel oil every couple of oil changes.
Vinny Red '86 944, 05 Ford Super Duty Dually '02 Ram 3500 Diesel 4x4 Dually, '07Jeep Wrangler '62 Mercury Meteor '90 Harley 1200 XL "Live your Life in such a way that the Westboro Baptist Church will want to picket your funeral." |
Just thinking out loud
Valvoline 20w50 and Amsoil 75w90. It's been ten years since the gear box oil has been changed and it's still like cutting through hot butter.
Different climates require different a viscosity. Find what is to your liking.
83 944 91 FJ80 84 Ram Charger (now gone) |
1988 944 2.5L 8-v NA 301k
Do you run the car during New Jersey winters or park it? If so, using the 20W50 or the 15W40 ? Thanks! mikey
'88 8v n/a 301k with 41k on current TBelt M454 M533 M650 M425 M418 ![]() New Feb'13 Bridgestone Grid 019.. awesome. Paid just $1,700 running & inspected. Big RUSH Fan! Lic Plate = LIFESON |
Mike A 9TECHNIK | TRANSAXLE ÄRA 1986 944 (Street); 1986 944 (Track); 1986 951; 1989 951 (3.0L 8V); 2000 996 Cab. |
Howdy...
yes, -10Celsius ( or 14Fahrenheit )... Page 111 of owner's manual. But the Cold Cranking Simulator specs on 20W oils in low temps seem pretty sky high... I know my old girl started much more easily this winter with 5W-40 synth.. vs. 20W50 in 2011. Going back to 20W50 for summer here.. Good thread.. Always love the passions that Oil Threads surface. Cheers all..
Valvoline 20w-50 VR-1 conventional for non-turbocharged motors. The key here is the temperatures that the 50 weight will be able to handle for the given tolerances.
Your motor is older both in design and miles so you have some "loose" tolerances. The heavy weight oil will help lubricate better. It also has the higher ZDDP content. For Turbo motors I run the Valvoline 20w-50 VR-1 synthetic due to the bearings of the turbo. STAY AWAY FOR REDLINE! It eats syncros! Use the Swepco from either this site or *****************. But like everyone else on here I'm an expert too. hahahah! You can run a lighter weight if you have tight tolerances. Our Cup car runs Mobil 1 0w-40 Synthetics
89' 951 Turbo S Race Car - SP-3, PT-B 87' 944 Diamond Blue Metallic - DD "Practice does not make perfect. Perfect practice makes perfect" - Ross Bentley |
AFM #725
How does GL-4 fluid eat synchros?
Thread Tools | |
Rate This Thread | |
