However, there is also one more component that might be faulty, the 68R 5W resistor that shunts the bulb. If the bulb has gone and the resistor is faulty then the required voltage will not be present at the alternator. Might be an idea to check that CCT too. 68R across the resistor with no bulb...probably about 10R (ish) when a good bulb is in circuit. |
Well looks like I'm wrong on the bulb I guess. That's a very, very stupid way to wire it if that is the case. A true parallel circuit wouldn't care if the bulb existed at all, let alone was blown out.
See diagram: http://forums.pelicanparts.com/uploa...1364378032.jpg What I find unusual is looping the CCT throught the alarm - not sure why they did that, anyone know? |
Any ideas where this resistor is located? Im assuming its in the instrument cluster somewhere
Im going to check the resistance of pin 3 and pin 4 to the alt warning socket. Should have close to no resistance
I know it's been covered, but it won't charge if the bulb is blown. If you pull the cluster and the bulb is still good, you've probably got a broken wire somewhere. If all else fails you can just run a diode from the 12v lug to the exciter wire lug (blue wire) and it will charge, but you're light on the dash won't work, but it doesn't already.
