Speedo dying at worst times!
It randomly died on this fun backroad with twisty corners, and would ONLY die on that road. Then I when I was late to school it died over and over! Of course on the way back when I wasn't in a hurry it was fine. I'm not sure where to find the contacts, can I get to them without pulling the cluster?
Old 03-26-2013, 08:10 AM
AKCJ's Avatar
What car?
On my 83 the speedo is driven by the drivers side front tire - easy to check by removing the cap on the hub (hubcap), make sure the clip is on. If you have small enough hands you can reach up from below the dash and turn the locking ring where the cable attaches to the back of the speedo. If you remove it you can push the speedo out to take a better look at it.
Good Luck.
Red 83 944
Old 03-26-2013, 09:12 AM
it's an S2. Would it work the same with mine?
Old 03-26-2013, 09:27 AM
Frankly my dear....
rhett's Avatar
No, the S2 has a speed sender mounted on the output shaft of the transaxle as it is an entirely electronic speedo. It could be a bad connection there. Best to check here first, unclip the connector on the top and clean the contacts, spray with WD40 or similar, see how it goes..
If that is not the problem, then you probably will have to remove the cluster to check connectors, etc on the back. It is not too much of a problem, just a bit fiddly..
Porsche - accept no substitute
Blue 1999 Boxster - Brief encounter! Black 1988 944S - Ongoing project
Black 1987 944S - Gone but not forgotten
Metallic Black 1980 924 - Those were the days....
Red 1979 924 - Hmm Minerva blue 1979 924 - Where it all began!
Old 03-26-2013, 10:42 AM
AFM #725
Gawernator's Avatar
I have a nice writeup on removing the cluster and fixing it
Old 03-26-2013, 03:16 PM
RedBaron's Avatar
Check the connection at the transaxle.
Old 03-26-2013, 03:34 PM
sjv sjv is offline
I thought the speedo problem's were the plastic gear breaking myspeedo would work sume time's then bounce on &off and nothing now also the shift indicater does'nt work are they connected though the DME
Old 03-26-2013, 03:43 PM
Frankly my dear....
rhett's Avatar
The speedo 'plastic gear' is part of the motor drive to the trip meter, not part of the actual gauge itself. If the speedo is bouncing on and off I would suspect a bad connection or ground. There are plenty of threads about cleaning grounds and checking connections. If the auto shift indicator is also failing it looks like a related connection problem.
Of course, other related problems could be:
  • faulty speed sender on transaxle (unit or connections)
  • wiring fault (sender to cluster)
  • speed sender drive shaft broken
  • dry solder joints on the speedo circuit board, and so on...
The speedo is not connected via the DME, however, the tacho is.
Old 03-27-2013, 03:06 AM
Frankly my dear....
rhett's Avatar
Just here.....
Hope that helps..
Old 03-27-2013, 03:16 AM
Next time it dies gently wiggle the ignition switch... if it starts working then the electrical part of the ignition switch is bad. I had an s2 that would do this I could wiggle the key and it would start working.
Old 03-28-2013, 07:03 AM
AFM #725
Gawernator's Avatar
Hey so the transmission is silver under all the dirt LOL
Old 03-28-2013, 11:40 AM
A silver tranny is just a myth!
Old 03-28-2013, 11:42 AM
I don't have the auto shift indicator. Of course my speedo worked perfectly yesterday, I wasn't late for anything....
Old 03-28-2013, 11:44 AM
