Rubbing belt on water pump pulley
Hi folks,
I just put in new belts and water pump on my 87 944t. The problem I ran into is that the belt for the balance shafts is rubbing against the waterpump. Just slightly but it does rub. Any idea how to eliminate this?
Picture attached.
Thanks,
Old 03-28-2013, 04:05 PM
Toofah King Bad
Rasta Monsta's Avatar
Put the belt cover on.
» 1987 924S Turbo - Got Boost? «
"DETERMINATION. Sometimes cars test us to make sure we're worthy. Fix it." - alfadoc
Old 03-28-2013, 04:10 PM
Andrew Gawers' Dad
CHICKS's Avatar
How does that help?
Old 03-28-2013, 04:39 PM
the balance shaft belt tensioner (the pulley on the eccentric on the bottom passenger side). i believe you should be turning it clockwise to tension the belt. you are probably turning it the other way to tension the belt, which is raising it up towards the pump.
Old 03-28-2013, 09:37 PM
Thanks,
Never thought of that. Just assumed that it had only one lobe.
Old 03-29-2013, 07:20 AM
Proprietoristicly Refined
John_AZ's Avatar
Correct! Clockwise on the BB tension roller.
J_AZ
1988 924S, 85,750K ..+ 1987 924S, 154K DD (+15K est. bad odo)
Old 03-29-2013, 10:20 AM
