resealing rear hatch
Hello, I regassed my rear hatch struts in an 84 944 and it was not long after that the age of the rear window seals objected and the glass along the roof edge of the hatch broke away from the frame. I have removed the hatch and removed the frame and cleaned all the old sealer away. I noticed that the sealer where the strut fixtures are was much harder than the rest of the sealer, was there anything different done in that area to help with the pressure or do I just use the one sealer all round ?. I am using a specialised windscreen sealent so I hope that does the job. Also now I have the hacth off, I want to remove the poor attempt on the rear hatch only of window tinting. There are area's of bubbling etc. Any tips on getting this stuff off ? I have been able to pull some off, it leaves a glue residue ontop of another layer of tint that does not want to come off, I have removed all the glue no problem, Any ideas ?
Old 03-28-2013, 11:28 PM
Proprietoristicly Refined
John_AZ's Avatar
SACKO7,
This is the most recent thread on resealing using the latest professional products.
Rear Hatch Reseal - Might have it down - DIY - Rennlist Discussion Forums
Of course you could just remove the hatch struts and use a broom stick.
Normally it is not wise to install brand new hatch shocks (or regassed ??) on an old hatch- separation is assured. I buy used hatch shocks from members every few years.
GL
J_AZ
1988 924S, 85,750K ..+ 1987 924S, 154K DD (+15K est. bad odo)
Old 03-29-2013, 06:23 AM
honerboys's Avatar
the glue on the tint is water soluble - try carefully using a single edge razor to get some off then spray with water - let it sit scrape a little more - more water - can be time consuming
84 928 S - SOLD
2012 Cayenne S
Old 03-29-2013, 09:45 AM
