-   -   Led instrument cluster bulb identification (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/742159-led-instrument-cluster-bulb-identification.html)
DP944 04-01-2013 06:38 AM
944online sells a complete led instrument cluster upgrade. it comes with 17 twist style bulbs for the warning lights and 3 wedge style for the illumination. ive already identified the 3 illumination bulbs, but would like to figure out what the 17 others are. superbrightleds.com has pretty good pricing.
http://img.tapatalk.com/d/13/04/01/yra5u4up.jpg
oh and ive done a lot of research and i am aware that certain bulbs in the instrument cluster, such as the alternator and airbag light bulbs should be left alone.
I believe user by the name of "9ff" had some experience with this, but i pulled his list of leds from another thread and im a little confused. arent all 17 bulbs the same? it looks that way in the picture of bulbs that 944online sells.
Heres "9ff"s list
* 74-xHP Wedge Base LED Bulb (10 needed) #This is for speedo, rpm, oil, volt, clock, and centerconsole#
* B8.5D Instrument Cluster LED Bulb (7 needed) #This is for left gauge# I would get 3+ more cus they are pretty easy to break when putting them in.
* 3022-x4 LED Festoon Bulb (1 needed) #This is for the glovebox#
* 4211 LED Festoon Bulb (2 needed) #This is for the luggagelight in the back and domelight
like i said ive done a lot of research, so those of you who prefer filament style bulbs, save your opinions. ive read through a number of your threads.
Thanks guys
DP944 04-01-2013 06:53 AM
http://img.tapatalk.com/d/13/04/01/8a4abuzy.jpg
http://img.tapatalk.com/d/13/04/01/eta8ysyq.jpg
These pics are from *****************. Looks to me like there are 3 different types of bulbs. the 4 1.2w instrument warning bulbs. The 3 illumination bulbs, then 18 (1.2 or 2w) warning bulbs on the back.
DP944 04-01-2013 01:43 PM
Bump
J1NX3D 04-01-2013 07:25 PM
I have a 968 cluster out in front of me and it shows only 2 different bulb types. the 3 x 3w illumination bulbs and then all the rest are 1.2w bulbs for the warning lights.
DP944 04-02-2013 04:35 AM
thats what i thought. Wondering if "9ff" was referring to the early instrument clusters
DP944 04-02-2013 04:01 PM
Bump.
