AFM #725
Gawernator's Avatar
Exhaust leak - rusted bolts
So, I know this has been covered before, but I was looking for tips on cutting/drilling the bolts from manifold to catalytic converter pipe. (6 total) I was able to get two out with an impact gun.. They were so rusted through... All the other bolts I can't get to budge, tried a torch and PB Blaster. Some of them are rounded off now. I also have a minor leak now lol from only having one bolt on the second flange.
I have a new rotary tool so any experience with removing these ****ers?
Old 04-02-2013, 11:24 AM
Volhv's Avatar
Try shearing them off with brute force and ignorance. If they are the original bolts that should be 13mm, and are a bit stripped, pound on a 1/2 socket. (it's just a hair smaller than 13mm)
While that should work... if you still can't get them off, split the nuts with a cutting disk.
1986 944 NA Sapphire Metallic
http://944porsche.blogspot.ca/
Old 04-02-2013, 02:48 PM
AFM #725
Gawernator's Avatar
I will try that, thanks yes they are the 13 mm original and are badly rusted. Both my friend and I couldn't get them to budge... And the space doesn't really have any room for a long breaker/cheater bar.
Old 04-02-2013, 03:06 PM
flash968's Avatar
it does if you have a long enough extension. i use a 12" inch and have plenty of room.
Old 04-02-2013, 06:08 PM
AFM #725
Gawernator's Avatar
I'll see if I have one
Old 04-02-2013, 06:41 PM
Wrench Therapy Inc.
Exclamation
Mix up one part ATF and one part lacquer thinner and squirt that on the bolts. Beats most penetrating oils. Keep what you don't use in a tightly closed container. That stuff creeps good. Accidents has a nut splitter to break off badly rusted nuts. Wear face should when breaking nuts!
Old 04-02-2013, 07:42 PM
Wrench Therapy Inc.
Phone spelling for me. Should be Sears has a nut splitter.
Old 04-02-2013, 07:43 PM
Volhv's Avatar
See if you have a universal joint also... If not, add it to your shopping list.
Old 04-02-2013, 07:46 PM
AFM #725
Gawernator's Avatar
A what.. is that the spinny thing? I think I have one (my dad's technically) but do they make them impact strong?
Watchdog Armory Racing AFM #725 Thanks to my 2017 Sponsors: JPH Suspension | AXO | Armour Bodies | BELL Helmets | Braven | EVLUTION Nutrition | Forcefield Armor | FunTrackDayz | Galfer | Motion Pro | MOTUL | Matrix Racing Concepts | ODI Grips | OGIO | Shorai Inc. | SPEEDMOB | Vortex | Woodcraft | Wicked Audio
http://www.gawerracing.com
Old 04-02-2013, 09:04 PM
Andrew Gawers' Dad
CHICKS's Avatar
They make one for impact, yes.
Old 04-02-2013, 09:12 PM
AFM #725
Gawernator's Avatar
And by my Dad I don't mean that guy ^
Old 04-02-2013, 09:43 PM
Chunkerz's Avatar
Soak them in PB blaster or your penetrating oil of choice. I soaked mine for a week, but they still wouldn't budge. To remove mine I had to pound on a 1/2 inch socket and push the wrench with my foot. Eventually the bolts just broke in half and I continued on my way. A universal joint is almost necessary to remove a few of them. I don't know how you'd fit a Dremel tool or whatever up there to cut them off if that fails. That space is pretty tight. You could always remove the headers and the 3 bolts at the end of the cat and just drop the whole exhaust. Getting to the nuts on the head seems easier than the 6 bolts on the end of the headers
Old 04-02-2013, 11:36 PM
AFM #725
Gawernator's Avatar
Headers is making it more difficult, and the dremel tool is pretty thin.. I used PB blaster, will try beating them to **** more before cutting
Old 04-03-2013, 12:45 AM
Toofah King Bad
Rasta Monsta's Avatar
Take it easy on "beating" or you'll be WTB:Manifold.
» 1987 924S Turbo - Got Boost? «
"DETERMINATION. Sometimes cars test us to make sure we're worthy. Fix it." - alfadoc
Old 04-03-2013, 07:13 AM
AFM #725
Gawernator's Avatar
I meant I'm not going to mess with the exhaust manifold, no sir
Old 04-03-2013, 07:24 AM
