-   -   Trick A/C question. (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/742419-trick-c-question.html)
j911brick 04-01-2013 10:39 PM
Trick A/C question.
1984 944. A/C does not turn off when ignition is turned off. If you turn off the A/C manually it will stay off till you start the car again. Has anybody seen this problem?
v2rocket_aka944 04-02-2013 07:32 AM
fried AC relay?
j911brick 04-02-2013 06:08 PM
Originally Posted by v2rocket_aka944 (Post 7364249)
fried AC relay?
Turned out the owner had the wrong relay in there. Now only the driver side fan comes on with the A/C.
