Trick A/C question.
1984 944. A/C does not turn off when ignition is turned off. If you turn off the A/C manually it will stay off till you start the car again. Has anybody seen this problem?
james www.gruppe9autowerks.com Its not how fast you go...its how you go fast |
fried AC relay?
Turned out the owner had the wrong relay in there. Now only the driver side fan comes on with the A/C.
