-   -   Startup tips needed (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/744020-startup-tips-needed.html)
kfanazini 04-11-2013 03:27 AM
Startup tips needed
Members,
My car has been in winter storage since Thanksgiving, does anyone have any tips for the first start of the season, or any links to past threads?
Thanks in advance,
Ken
Techno Duck 04-11-2013 06:20 AM
Check oil, pull DME relay and coil wire. Crank till you see oil pressure. Start and drive.
rick13 04-11-2013 07:19 AM
Search 'youtube' for Arthur Fonzarelli attempting to jump a shark on his motorcycle. This should lend some useful insight.
Lol...good luck !
Correction on water skiis!!! Lmao
kfanazini 04-11-2013 08:35 AM
Ok. That's what I was going to do, thanks for the reply.
princej 04-11-2013 10:58 AM
report back if yours starts, mine did not.
I had to spray in starting fluid, but learn from mistake, spray in starting fluid, then reconnect the hose to the MAF.
took me hours to and only I drained half the gas tank did I realize it.
