seven944's Avatar
Brake booster vaccum?
With my superchargers outlet direct to the intake manifold, and the throttle body is upstream and so is the afm, so with the brake booster vaccum, where could I draw it from?
Old 02-12-2013, 07:49 AM
between the throttle and the blower.
Old 02-12-2013, 08:08 AM
9FF 9FF is offline
9FF's Avatar
Anywhere on the intake should be fine. It's not drawing any pressure from the manifold, it's just pulling a vacuum.
If you are using a turbo intake there are places cast in to pull a vacuum otherwise you will have to drill a hole for an outlet.
Old 02-12-2013, 08:09 AM
one of gods prototypes
bell's Avatar
Seven I was discussing this with don......
He believes we will not have enough vacuum and is suggesting a vacuum pump.......I'm thinking a large resivoir and a check valve......I'll know soon... Lol
Brought to you by Carl's Jr.
Old 02-15-2013, 08:20 PM
seven944's Avatar
So ill plumb it in, get it running, and mash the throttle headed straight for a brick wall. Then ill know! Haha
Old 04-13-2013, 07:15 PM
