-   -   Chassis after dismantling? (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/744519-chassis-after-dismantling.html)
kens_74_911s 04-15-2013 03:13 PM
pts
write a quick list of what is left on it, I see its an 87 so late offset. hubs etc.
wheels
Ft hubs struts
calipers FT
A ams
pwr steering rack
under hood items
transmission
etc.
etc.
or do a few more pictures under hood inside and rear
mhariush 04-15-2013 03:26 PM
Originally Posted by v2rocket_aka944 (Post 7387844)
Im now tempted to cut the roof off from the belt line and make a buggy...
that would be interesting :) well, if you want the chassis its free for pick up :)
mhariush 04-15-2013 03:34 PM
What's left:
Everything, more or less....from little clips to assemblies :)
Engine (have not pulled)
computer dme
final stage/ECU
front struts Black Porsche (good)
rear after market (good)
transmission LSD (have not pulled)
wheels (phone, decent but needs a repaint)
All suspension parts
Exhaust with new cat, but has rusted together (cat and muffler part)
interior parts
seats but trashed, good for core
dash trim (good)
speedometer trim (good)
Center console (good, burbundy but with some paint stains it looks like)
shifter bezel trim (good)
shift lever (good)
Some carpet pieces are good
Door panels are decent
back seat panels are decent
hatch good
right tail light
rear turn signals
front right turn signal
head light conversion bulbs that takes H4 bulbs
Doors good but needs paint
hood, good but needs paint
sunroof good but needs paint
Here's the engine before i started picking. I still have everything. But damaged the windshield washer tank.
https://dl.dropboxusercontent.com/u/...2015.33.39.jpg
inside, very dirty but cleaned up pretty good
https://dl.dropboxusercontent.com/u/...2015.33.08.jpg
https://dl.dropboxusercontent.com/u/...2015.32.54.jpg
https://dl.dropboxusercontent.com/u/...2015.32.29.jpg
Sold so far:
AC Unit
Washer Pump
Fan Relay
Arm Rest lid
Hatch Pins
Dist cap and wires (kept)
TE=kens_74_911s;7387975]write a quick list of what is left on it, I see its an 87 so late offset. hubs etc.
wheels
Ft hubs struts
calipers FT
A ams
pwr steering rack
under hood items
transmission
etc.
etc.
or do a few more pictures under hood inside and rear[/QUOTE]
kens_74_911s 04-15-2013 03:44 PM
yea there is still quite a bit there....
PM me on the climate control you need to know how to pull those dash bits carefully to access it so you dont bust it all up though.
mhariush 04-15-2013 04:01 PM
that's one of the few things that sold unfortunately, i called it the AC control unit. But the other trim pieces around it are good. I've pulled a few of them on my previous car so have have that down :)
kens_74_911s 04-15-2013 05:19 PM
pts
Hey I will PM you done a few of these.
gkovakas 05-07-2013 02:10 PM
I need the driver side window switch bezel plate.
guru944 05-07-2013 03:54 PM
Breaks my heart
One more 944S "Rest in peace"
Only a 2 year (87-88) limited production 944 Model.
Later...
wilkrod 05-08-2013 09:05 AM
Battery box
Hi,
Can you cut the battery box area out for me?
If yes, just cut the biggest piece you can
Jeff
mhariush 05-12-2013 01:06 PM
Hi,
I can.
Tcrate 05-12-2013 05:41 PM
I am interested in the Trans. I will PM you.
Also interested in the Climate control switch on the dash.
Thanks.
mhariush 05-27-2013 11:17 AM
Hey guys,
sorry, been too busy with work. But now back in car mode. What parts are needed by people?
Pulled Trans yesterday.
https://dl.dropboxusercontent.com/u/...2017.55.35.jpg
kens_74_911s 05-27-2013 08:05 PM
yes
Originally Posted by guru944 (Post 7428702)
Breaks my heart
Later...
When they die others can live...http://i36.photobucket.com/albums/e3...ps68a09d6b.gif
http://i36.photobucket.com/albums/e3...1-28-13001.jpg
wilkrod 05-28-2013 07:43 AM
Battery box area
I can use the battery box area.
If you can cut from center of cowl, down thru center of driveshaft tunnel to floor board, and then over to the sill that would be great.
I have corrosion thru the floor of the battery area, which then leaked down the floor board, and into the inside of the sill area.
Jeff
