911tracker85's Avatar
HVAC challenges
got the 944S back on the road.
the interior vents blow HOT air, so checked the HCV with mightyvac and it works. not feeling any vacuum from the connection to the HCV, so zip tied closed and hot air stopped.
and the AC is inop. started checking and cannot get the compressor to engage when I jumper the low pressure switch.
so, before I tear the dash out, wonder if anyone knows if both could be caused by the HVAC control module in the dash.
reading the Clark's garage notes, searching threads, and starting to dig into the WSM.
Old 04-11-2013, 05:59 AM
16vCorey's Avatar
Both could definitely be caused by the HVAC control head.
Parting '84 944 with 103k. Pics here: http://smg.beta.photobucket.com/user/cheezus/library/944?fromLegacy=true
Old 04-11-2013, 06:52 AM
AC could be the relay
Old 04-11-2013, 08:21 AM
mhariush's Avatar
Blows lots of hot air? Probably a broken heater clip. They're a couple of bucks, get some spares.
Current: 87 944S Black/Black, 89 944 Turbo S ANDIAL White/Burgundy, 78 924 Black/Black, 17 Cayenne S, 03 Turbo X50 Aero
instagram @mhariush http://stores.ebay.com/Techniker-Parts/
Old 04-11-2013, 09:32 AM
mhariush,
my 87 944S is also blk/blk. PO developed heath issues and stopped driving much, and it finally stopped running. sat for a couple years.
very nice cosmetically and almost perfect leather interior. so just had to buy it and bring back to life. now running great and love the pull/sound of the 16v motor.
I have already checked the flap clips in the footwell and they are good and working. with the HCV zip tied closed the hot air stops.
I have not checked the AC relay yet.... trying to find what all relays, sensors, etc in the AC circuit that I need to check. did this to my 928 a few years ago, and it still blows very cold.
but with two different HVAC failures on this car, suspected I need to start pulling the dash.
Old 04-11-2013, 01:34 PM
mhariush's Avatar
gotcha. Maybe I didn't read carefully enough I'm pulling apart an 87 S now and I've just started taking out the HVAC, but had to stop as I couldn't get it out. There were some bolts there that I didn't see i think. So if you need one, I have one that was working according to PO.
Old 04-11-2013, 05:12 PM
great as I may. not sure how I will verify it the HVAC controls are bad.
it will be another week before I get back into this issue. spring time 'honey dos' galore this week.
Old 04-14-2013, 06:31 AM
Patrick
pfarah's Avatar
Just a friendly suggestion; you may want to replace the drier when you get to the point of recharging the system. It will make a strong difference in AC performance.
1984 944 NA, constant tinkering
1983 "Beastie" - Safari Build
Old 04-14-2013, 10:24 AM
pfarah,
I actually plan to replace all the accessible O rings, drier, and have the AC hoses rebuilt. when I get into something like this I have learned it is best to just do it all WYAAIT.
but have not had time to get back into working in this.
thanks again for all replies/ideas.
Old 04-17-2013, 06:34 AM
