AFM #725
Break free this nut? How?
So.. my shop friend broke a 24mm Craftsman Pro series socket and could not break free this nut with his air-impact gun using an impact socket either. It's the 24 mm nut for adjusting the ride height in the rear, i.e. trailing blade thing. What should I/we try to do? I'm sure this hasn't budged since 1986 lol. Is getting a cheater bar on and lowering the car and using the weight of the car to break it free a good/safe idea?
Watchdog Armory Racing AFM #725 Thanks to my 2017 Sponsors: JPH Suspension | AXO | Armour Bodies | BELL Helmets | Braven | EVLUTION Nutrition | Forcefield Armor | FunTrackDayz | Galfer | Motion Pro | MOTUL | Matrix Racing Concepts | ODI Grips | OGIO | Shorai Inc. | SPEEDMOB | Vortex | Woodcraft | Wicked Audio http://www.gawerracing.com |
Penetrating lubricant?
Well, don't be under the car when you're doing this. If you use the weight of the car, stand back and behind something. Something could snap and fly through the air.
AFM #725
It has come to my attention that this nut may be reverse threaded. Surely somebody has adjusted the trailing blade before?
I don't remember any of the nuts being reverse threaded, but it's been a year since I took the suspension apart. I Used a shop jack at the shaft of a large ring wrench. I gently jacked the shaft upward to loosen while tapping the head of the bolt using a hammer to break it free.
1990 944 T: 100 000 km/63K miles, 1997 986 2.5L: 95 000 km/60K miles, Living in the trackless land of plenty! |
AFM #725
Hmm.. so you jacked up a wrench. Nifty. You just whacked the nut with a hammer? or you hit the head of the bolt on the opposite side?
Frankly my dear....
This nut is torqued to 180 ftlbs at the factory, then 25 years of use and corrosion, it is just possible that the bolt will snap as it is very hard hi-tensile steel, so dont be too violent!Remember you will need to loosen both bolts: ![]() Don't even think about trying to turn the large bolt head until the nut is loose as this thing is eccentric - however, once you have got it loose, take it out and clean everything as crud will have built up on the threads and in the hole.
Porsche - accept no substitute Blue 1999 Boxster - Brief encounter! Black 1988 944S - Ongoing project Black 1987 944S - Gone but not forgotten Metallic Black 1980 924 - Those were the days.... Red 1979 924 - Hmm Minerva blue 1979 924 - Where it all began! |
Eric
I used an impact wrench on the nut, and needed to hold it on for about 30 seconds before it budged. You can't turn the eccentric bolt as it will never move until the nut is removed from behind.
Eric Last edited by Eric_Oz_S2; 04-25-2013 at 06:05 AM.. |
944 addict
I'd call the Mythbusters for help.
3 944's, 2 Boxsters and one Caman S, and now one 951 turbo. Really miss the Cayman. Some people try to turn back their "odometers." Not me. I want people to know 'why' I look this way. I've traveled a long way and some of the roads weren't paved. |
AFM #725
Thanks!
White and Nerdy
This turkey was stronger than my axel nuts. It was heavily corroded to the bolt. Penetrating oil every hour and running it with the impact for 30 seconds eventually got it.
Shadilay. |
I'd put a torch on it until its glowing. Then whack it with a hammer a few times or put a whindy gun on it. It'll come off.
AFM #725
Okay, sweet. My next question then is, if I torch this sucker, do I have to replace it? Or can it be used again still.
I would replace it. Heating it until it is glowing will alter the hardening.
AFM #725
Heat may be a last resort then..
Frankly my dear....
Of course you could always try a nut splitter tool (if it fits??).
