Brembo brake pistons question
Shouldn't all 4 pistons come out at the same time after pushing on the brake pedal? I had to pump the pedal and eventually the other two pistons creeped out. (driver side, right is the back/bottom).
'90 944S2 cab - sold after 20 years, will not be forgotten. '04 Mercedes SL500 - Nice but my S2 was more fun to drive. |
White and Nerdy
Once one piston drops and it loses its seal, you keep pushing fluid into air to try to get the others, hence the pumping.
To all come out at once, they would each have to have the same release length, and same friction. When taking apart my single pot calipers, I've found some to be in need of grease, and not as willing to move. I've yet to do anything with S2 calipers, so I'm afraid I'm not much help.
Shadilay. |
Frankly my dear....
If the pistons are all moving freely and not sticking, then yes they should all come out at the same time. However, in your photo you have removed the brake pad and so the hydraulic pressure will move out the pistons with the least resistance first. The ones that move later have obviously higher friction - corrosion in bore, sticking seal, etc. Pumping the pedal is necessary to get a greater amount of fluid into the caliper as the pistons are moving to the extent of their travel. It looks like a caliper overhaul is necessary, as ideally you do wnat them all to operate as closely as possible to prevent uneven brake pad and disc wear, as well as under-performance when braking.
Porsche - accept no substitute Blue 1999 Boxster - Brief encounter! Black 1988 944S - Ongoing project Black 1987 944S - Gone but not forgotten Metallic Black 1980 924 - Those were the days.... Red 1979 924 - Hmm Minerva blue 1979 924 - Where it all began! |
AFM #725
Rebuild time!
Watchdog Armory Racing AFM #725 Thanks to my 2017 Sponsors: JPH Suspension | AXO | Armour Bodies | BELL Helmets | Braven | EVLUTION Nutrition | Forcefield Armor | FunTrackDayz | Galfer | Motion Pro | MOTUL | Matrix Racing Concepts | ODI Grips | OGIO | Shorai Inc. | SPEEDMOB | Vortex | Woodcraft | Wicked Audio http://www.gawerracing.com |
That's about right, the two bigger bores come out first and quicker than the two smaller bores.
I'll check the other calipers tomorrow and see how they look.
It's no wonder my brakes have been so crappy lately, only ONE piston even came out on my passenger side. I'm surprised the brakes aren't much worse than they are.
AFM #725
Pssh, it's fine. Don't worry about it
Hi Marko, If you are going to replace the Brembo Caliper Seals be prepared to pay around $50.00 each per Seal.
Cheers, Larry
Retired USAF and Civil Service, 1985.5 NA Graphite Metallic, A never ending work in progress, 1992 968 Horizon Blue Cab "New Toy"
Searching some posts, I found this link Replacement Rotors, Pads, Hardware
which sells a kit with 2 dust boots and 2 pressure seals for $35, but I'm not sure what size to get. I measured 30/34 for the pistons, but I don't think that's right. I saw a lot of posts mentioning 36/40 and the PET is a little confusing for me on the size.
