Porsche Crest car not starting
My problem is my 1986 944 will not start it will turn over. everyonce in a while the car does start. But when it does and I drive it a little while the car dies out and now I'm stranded.I have started to run out of ideas as what I should do. I put in a new DME relay, fuel pressure relgulator, fuel filter, timing sensors, dist. cap, rotor, wires, plugs. If anyone can help me with this problem I would be eternily gratful. I miss driving my baby.
Old 07-18-2002, 07:06 PM
Hey,
if you can how about you try switching your computer with that of another similar model 944 and see if that causes any change in your problem.It Could be a cold solder in the computer.See if this works being youve tried everything else.
Jurg
EightyoneMotorsports.
Miami,Fl
Old 07-18-2002, 07:16 PM
RobertMacDonald
Guest
Posts: n/a
Yo Irish, I'm just across the river from you, just beyond Scotia. I have an 84n/a that we can swap computers, if they'll fit. I'm not sure of the compatability pre v. post 85.5.
PM me if this works, otherwise lets meet for a beer and go for a drive.
Old 07-18-2002, 07:48 PM
