Motor Head
Timing belt replacement time
Is there anything besides the belt, tensioner, and idler that I should replace to do timing belt replacement? All of the front end seals are good and I'd rather not disturb them, and I'm not doing the water pump as that was replaced recently enough that I'm not worried about it. Is there anything else I should be concerned with, or does that cover it?
2013 Ford Focus SE - 5spd mtx, Spectre filter, Unleashed E85 Tune, much more to come. - DD
2011 Ford Flex - Catless Downpipes, lightweight Mustang Motorsport 20x8.5 wheels, 3 bar MAP, Unleashed 15 psi tune - SOLD
1986 944 Turbo - 100K mile cream puff - FOR SALE
Old 05-21-2013, 05:27 AM
If you have no leaks and you don't have the auto tensionier which I don't think that 86 had you should be ok but i would also replace the balance belt and idler as well.
Old 05-21-2013, 07:42 AM
One thing I did to my 83 was mod the inner timing cover so I could get it off without removing the crank sprockets. Makes water pump changes easier. Some folks like to check the cam belt tensioner stud just to be safe, too.
+1 to the bal belt & idler too.
'84 944 - new-to-me DD!
'83 944 - looks like ass, runs like horse - in primer.
'82 931 - roadster project - forever incomplete.
'80 924 - spouse's yellowjacket.
Some wrecks and a 924 racer.
Old 05-21-2013, 08:30 AM
Redline Racer
HondaDustR's Avatar
Pictures or template for that? Does it retain the lower mounting bolts? It's a PITA to pull the crank pulleys every time and I have a water pump job this week.
1987 silver 924S made it to 225k mi! Sent to the big garage in the sky
Old 05-21-2013, 08:54 AM
I had the early inner cover. First I roughly copied the late cover cutaway for the water pump et al, and then I cut the inner cover at the crank, keeping one lower mounting bolt on the smaller piece I'd created. It works fine - after all, the inner and outer covers are flanged to fit together and the one remaining mounting bolt keeps the small pie-shaped lower piece secure. Sorry, I don't have pics. I still have to finesse the inner cover off the engine but it sure beats having to take everything apart just to change the pump.
Old 05-21-2013, 10:46 AM
