Steve Sims
simssj's Avatar
'87 924S Speedometer wires?
After a lot of effort and a little cursing, I got the instrument cluster removed and my speedometer is in hand. (It's the "proper" 3-unit IC; gauges, speedo and tach, from left to right.)
I'm pulling it out because the odometer has been stuck on 39K since Reagan left in office.
When I pulled the speedometer, there was a two-wire connector attached to a circuit board on the back of the unit. It's got a "spade" (?) connector, but I will be damned if I can see where it might have been plugged in inside the dash.
Wires are red and green, with about 7 inches of length between the speed head and the connector.
I've searched the wiring diagrams for a clue, but they only show the (expected) illumination and grounds.
Can some kind soul give me a clue as to what these wires are for?
PS: I haven't disassembled the head unit yet, but I'm expecting to find mangled gears (like everyone else). I may 'punt' and take it to the local speedo shop and let them have at; my eyes aren't what they used to be for such close-quarters fiddly work.
Old 06-11-2013, 12:37 PM
1983 944 N/A
POPS 83 944's Avatar
They are used for the mile per gallon gauge on the tac, At lest on my 1983 they were
"To my family, the 944 is more than a new car. It is a new and true Porsche.
At Porsche, excellence is expected."
Dr. F. Porsche Stuttgart
Old 06-11-2013, 12:51 PM
Proprietoristicly Refined
John_AZ's Avatar
That little chip board on the 924S /944 is the Hall Sensor.
Pelican Parts - Automotive Parts and Accessories - Porsche & BMW
Pops is correct for the 944,
For the 924S it connects to the "upshift" indicator" bulb on the tach between the 3 & 4--tells you when you should shift UP.
J_AZ
1988 924S, 85,750K ..+ 1987 924S, 154K DD (+15K est. bad odo)
Old 06-11-2013, 01:17 PM
Steve Sims
simssj's Avatar
I did not know I had an upshift indicator on the tach. Huh.
Well, OK!
Thanks, guys. I can rest easy that when I put it back together I may actually get a "new" feature!
...sjs...
Old 06-12-2013, 02:34 AM
Tags
924s speedo odometer
