Battery not charging
My 83 944 na battery keeps dying so I took it to auto zone and had them test the battery they told me the alternator is not charging the battery, so I removed the alternator and took it in and they put it on the machine and it passed, I took the battery off and another store tested the battery and he said the battery lost a cell so I bought a new battery and put it on and once again the battery dies. So I took it back in and the meter said alternators not charging again. Could it be something inbetween the alternator and battery? What is going on??
Old 05-19-2013, 10:45 AM
I have an '86 and my problem with charging was the voltage regulator... rear of alternator. The thing lasted for over 20 years.
86 951 blk
Old 05-19-2013, 11:04 AM
But wouldnt that show up on the test they ran when I had took off the alternator?
Old 05-19-2013, 11:19 AM
spring loaded contacts... wear on the contact itself and reduced tension on the spring could cause an intermittent connection until it actually permanently fails...
86 951 blk
Old 05-19-2013, 11:54 AM
944 addict
mytrplseven's Avatar
Send a message via AIM to mytrplseven
I'd start with the alternator belt tension, voltage regulator, then the alternator itself. Put a voltmeter on the battery when the engine is running and see if you have at least 13.8v. If not, and with the RPM over 2000 you still don't have it, then do the above in order.
3 944's, 2 Boxsters and one Caman S, and now one 951 turbo. Really miss the Cayman.
Some people try to turn back their "odometers." Not me. I want people to know 'why' I look this way. I've traveled a long way and some of the roads weren't paved.
Old 05-20-2013, 11:55 AM
I'm not sure if the 944 is like the 924. but on mine, if the battery light in dash doesnt come on when KO EO you won't get a charge. replace light bulb in dash, excite wire will activate alternator. Thats based off my 924, I just went through all this.
Old 05-21-2013, 10:27 AM
In my experience, the alternator needs to be replaced every 5ish years. My current one is on year 7 though, but generally it's been 5.
Old 05-22-2013, 07:23 AM
looking back on this, the brushes on your regulator look shot. They should be sticking out about another 1/4 inch to make good connection. if you replace the alternator... dont forget to remove the condenser off the back!
after you hit 4k rpm you start hearing it through the speakers
Old 05-22-2013, 07:46 AM
DP944's Avatar
check to see if you have 12v to the small blue wire with the key in the on position. also check to see if your little alternator charging light comes on at the cluster with the key in the on position. i had to run a new wire from the instrument cluster to the alternator to replace the blue wire because there was a break in the wire and my alternator wouldnt charge the battery.
"I couldn't find the sports car of my dreams, so I built it myself." Dr. Ferdinand Porsche
Old 05-24-2013, 05:05 AM
