924 - first 100 miles
Well I got her running, took her on the maiden voyage last night. I've established.. I'm not a big fan of the 4 speed.. is there a 5 speed transmission that can be swapped in? I also lost my fuel guage after driving for a bit and fueling up. Bad ground? another item ran by a light bulb circuit?
Old 05-16-2013, 11:40 AM
redstrosekNic's Avatar
Later 924s came with a 5 speed. I do not know exactly what a swap entails, though. Why don't you like the 4 speed?
Dustin
Old 05-16-2013, 12:03 PM
Dave Colangelo's Avatar
I hate to be the one to say this but for the price buy a 944.
Sell your 924 get maybe 1K or more, take the money you would have used to buy a new tranny and what ever you needed to get it in. Save a bit more and buy a semi-decent order 944.
If you really want to swap, the later ones had 5 speeds to the best of my knowledge.
Regards
Dave
'78 911SC Targa (Back In Action!)
'00 996 Carrera (New kid on the block)
'87 944 (college DD - SOLD)
'88 924s (high school DD - Gone to a better home)
Old 05-16-2013, 02:01 PM
I don't going 70 and wrapping out at 4k. I feel like a 5th gear would unlock so much more potentional with this car
Old 05-16-2013, 07:18 PM
Sorry. Don't like going 70 and wrapping out. Completely left a word out lol.
Hey while I'm still live here, what is the recommended oil? When I managed to blow out all my oil I instinctively put 10/30 in. but I kinda feel like its too thin compared to what I cleaned up
Old 05-16-2013, 08:53 PM
Chunkerz's Avatar
Brad Penn 15w40 is what I'd recommend. Others say to use 20w50, but you're pretty far up north so I'd use something a little thinner.
Old 05-16-2013, 11:07 PM
924RACR's Avatar
5-speed swap is indeed a bolt-in if you use the correct one - but will require a few parts... mainly the shift rod is different, in addition to the trans... and a very nice one to have.
Don't worry about trying to shop for a '44.
Vaughan Scott
http://www.vaughanscott.com
http://www.924.org
Old 05-17-2013, 07:26 AM
I live in NE Ohio, and drive the car in temps down to around 40F without any issues. I run Valvoline VR1 20W50. My oil pressure light flickers at idle on hot days, which is completely normal per the owner's manual. I would think 15W40 might be a bit thin.
Dustin
Old 05-17-2013, 08:49 AM
if you use the correct one? bolt in sounds quite nice lol. I will start digging into it and learn more about it. is there a specific transmission i should look for?
Old 05-21-2013, 11:31 AM
924RACR's Avatar
Transaxle
That should get ya started...
Vaughan Scott
http://www.924.org
Old 05-22-2013, 04:53 AM
Too bad you are not closer. I am in Ohio and have a '79 924 parts car (complete, but rust in the fuel tank) for $700. It has a Snail Shell transmission that would work for you.
Old 05-22-2013, 05:31 PM
924RACR's Avatar
Sorry, but the snail is not the one you want for a conversion... you need an '80-onward non-turbo, for the easiest swap (as noted in my link).
A 944 5-speed could be done, but requires torque tube and clutch disc swap as well... so a lot more involved.
Vaughan Scott
http://www.924.org
Old 05-23-2013, 05:05 AM
Speaking of parts car. Does anyone have a condenser near by? I'm tired of hearing my alternator once I hit 4k lol
Old 05-23-2013, 07:33 AM
Tags
924 , electric , fuel guage , transmission
