Oil pan
Question... It looks like my oil pan on my 924 has a crack in it.. but it doesn't leak at all. Was this just a manufacture flaw? I will post a picture shortly.
944 addict
It's possible it's a casting flaw if you're oil isn't leaking out. Is it on the bottom or the side where it might be above the oil level in the pan?
3 944's, 2 Boxsters and one Caman S, and now one 951 turbo. Really miss the Cayman. Some people try to turn back their "odometers." Not me. I want people to know 'why' I look this way. I've traveled a long way and some of the roads weren't paved. |
AFM #725
Road debris can also cause damage
Watchdog Armory Racing AFM #725 Thanks to my 2017 Sponsors: JPH Suspension | AXO | Armour Bodies | BELL Helmets | Braven | EVLUTION Nutrition | Forcefield Armor | FunTrackDayz | Galfer | Motion Pro | MOTUL | Matrix Racing Concepts | ODI Grips | OGIO | Shorai Inc. | SPEEDMOB | Vortex | Woodcraft | Wicked Audio http://www.gawerracing.com |
It is most likely a casting flaw. I have seen it on a number of pans. I have hit rumble strips with my spec car and broken some chips out the the bottom cooling fins but never cracked a pan. These pans are pretty bullet proof. The only damage I have seen to the pans is a rod through the side.
Jim Richmond 944 Spec race car, SoCal NASA & POC 01 Boxster S |
I'm on my phone I can't upload a picture from here. It looks pretty clean to me. And it's on the front, down and back.
![]() I know, i see the bigger problem leaking there |
944 addict
That crack looks like someone tried to hide it with hammering around it. If you plan to do a pan gasket replacement, I'd find another pan just to be safe. Also do the rod bearings and rod bolts while you're in there.
The newest of the noobs!
I have an n/a pan if you're interested, in Wisconsin.
1989 944 Turbo 2004 Jeep Wrangler Unlimited - Built! 1985 Saurer 6dm overland Swiss military truck/camper |
I have an oil pan from an 87 944S, that I haven't unbolted from the engine yet... I'm in So-Cal, if that's easier or cheaper with shipping...
Current: 87 944S Black/Black, 89 944 Turbo S ANDIAL White/Burgundy, 78 924 Black/Black, 17 Cayenne S, 03 Turbo X50 Aero instagram @mhariush http://stores.ebay.com/Techniker-Parts/ |
Different pan.
is it? i thought the block was the same. then count me out
924s, 944na and 944s all use the same oil pan. If its a 924, its the audi motor and different pan.
