Clutch pedal not returning
My clutch pedal is stuck down and has a couple of inches to move. The clutch does work and I plan to replace the master/slave cylinders. Would the clutch fork have anything to do with it or is it only related to hydrolic cylinders?
Old 05-24-2013, 06:24 PM
AFM #725
Gawernator's Avatar
Does it either stay all the way down or all the way up? When I was bleeding the clutch my first time, I had two problems, the blue hose from reservoir started leaking under the new pressure, and then I was having trouble getting the air out, in the meantime the pedal would hit dead to the floor. Proper bleeding with a Motive finally got it sorted out, along with a new hydraulic fluid hose.
Watchdog Armory Racing AFM #725 Thanks to my 2017 Sponsors: JPH Suspension | AXO | Armour Bodies | BELL Helmets | Braven | EVLUTION Nutrition | Forcefield Armor | FunTrackDayz | Galfer | Motion Pro | MOTUL | Matrix Racing Concepts | ODI Grips | OGIO | Shorai Inc. | SPEEDMOB | Vortex | Woodcraft | Wicked Audio
http://www.gawerracing.com
Old 05-24-2013, 07:18 PM
It's a couple inches from the floor. It will move enough to engage/disengage the clutch though. I have replaced the master cylinder about 7 years ago and it has only a couple years of use on it. The slave I think might be original.
Old 05-24-2013, 07:25 PM
AFM #725
Gawernator's Avatar
Also check to make sure that one hose isn't ballooning
Old 05-24-2013, 07:49 PM
Mein Gott!
Panzer909's Avatar
Mine did this for a minute right after I changed out my master/slave cylinder for about the 4th g*ddamn time over the course of owning the car
There is a small adjustable arm at the clutch pedal. It can allow for movement in either direction. I'd take a look at this first.
Johnny
1987 944S
1984 944 (R.I.P.)
1972 Triumph TR6 - 100% trouble free between breakdowns
2003 BMW 325xi
Old 05-24-2013, 08:10 PM
About a week ago I pressed the clutch pedal in and it returned fully. Then when I went to change gears the pedal didn't make contact with the metal shaft from the master cylinder until the pedal was pressed in half way. Since then I noticed it made contact at different positions over the last week. I had the pedal adjusted so there was about 3/4 of an inch of free movement before it made contact to operate the master cylinder. It feels to me that the hydrolics are not being returned to a fully decompressed state.
1984 944 NA 5spd
Old 05-25-2013, 02:51 AM
I would start by replacing the slave cylinder and while you are in there if there is any wear to the black hose that goes to the slave I would replace that as well. Some will tell you to replace the clutch master along with the slave.
Old 05-25-2013, 03:56 AM
I found brake fluid leaking from the clutch inspection hole. Will this ruin the clutch if it driven?
Old 06-08-2013, 07:46 PM
That would be a leaky clutch slave. I wouldn't drive the car till you replaced the part.
Old 06-09-2013, 04:36 AM
I had very similar problem. Replacing slave didn't solve it. Went ahead and replaced the Master and the hose that goes between the 2. Works like a charm now.
Guy
'87 944 (first porsche/project car)
Old 06-10-2013, 08:15 AM
Brake fluid at clutch inspection hole would be a leaky slave.
Old 06-10-2013, 08:46 AM
944 addict
mytrplseven's Avatar
Send a message via AIM to mytrplseven
You don't want brake fluid on the clutch plate. I recommend replacing the slave and the hose and then see how the clutch performs. If it grabs then your' plate has been contaminated with brake fluid.
3 944's, 2 Boxsters and one Caman S, and now one 951 turbo. Really miss the Cayman.
Some people try to turn back their "odometers." Not me. I want people to know 'why' I look this way. I've traveled a long way and some of the roads weren't paved.
Old 06-10-2013, 08:54 AM
