-   -   Can't keep an alignment... (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/754998-cant-keep-alignment.html)
Mike_944 06-09-2013 12:53 AM
I'm thinking control arm bushings? Mine look pretty bad.
:confused:
VirginiaF1 06-09-2013 06:46 AM
Last year, my factory original caster blocks and front control arm bushings were ugly.
Even after alignment, the 944's legendary steering accuracy was non-existent.
So, I lucked out and found sealed, factory 951 rubber caster blocks and the Weltmeister bushings all around up front.
Also have changed:
- all 4 wheel bearings,
- all 4 shocks/struts
- and ensured a solid ball joint pivot.
Sears completed a full re-alignment and WOW.
Still need to re-rubber the rear end.. ( Doh!)
mikepellegrini 06-09-2013 06:51 AM
Put it up on jack stands and start wiggling stuff and you oughta be able to figure out what needs to be replaced.
Gawernator 06-09-2013 04:34 PM
Lol SEARS did it? Lucky you.... they're so dumb here
VirginiaF1 06-09-2013 05:43 PM
Yup.. in fact JohnKoaWood suggested them.
They were great.. on my short list now.
Mike_944 06-10-2013 12:13 AM
Easy enough
Did you get poly or rubber bushings?
How many bushings are needed for each control arm?
VirginiaF1 06-10-2013 07:41 AM
I called 888-280-7799 and the splendid folks at Pelican parts hooked me up.
Urethane front bushings, rubber caster blocks and rubber sway bar bushings.
