-   -   Help identifying possible 944 parts please (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/755515-help-identifying-possible-944-parts-please.html)
Johnny B 06-12-2013 01:26 AM
Hello all,
I recently purchased some parts and there are some items I just can't identify. I have spend hours looking through Porsche PET but am struggling to find these parts and their potential part no's, any help greatly appreciated.
I am not sure if they are all 944 parts but thought this was a good place to start.
thanks in advance,
http://forums.pelicanparts.com/uploa...1371024711.jpg
http://forums.pelicanparts.com/uploa...1371024796.jpg
http://forums.pelicanparts.com/uploa...1371024825.jpg
http://forums.pelicanparts.com/uploa...1371024891.jpg
http://forums.pelicanparts.com/uploa...1371024986.jpg
http://forums.pelicanparts.com/uploa...1371025031.jpg
http://forums.pelicanparts.com/uploa...1371025070.jpg
http://forums.pelicanparts.com/uploa...1371025139.jpg
mhariush 06-12-2013 10:58 AM
The second to last one is the brake pad sensor. The others, not sure. Also hard to tell in the picture, too much contrast in them to make out details and shape. and also materials.
Johnny B 06-13-2013 12:02 AM
Thanks agreed it does look like brake pad sensor PET part no 944 612 212 00 Warning Contact
Appreciate the help, 1 down, many more to go
rhett 06-13-2013 09:21 AM
Second photo down shows some rubber seals. Don't recognise all of them, but the top one could be the piping that goes on the top of an oval dash instrument binnacle to seal it to the main dashboard assembly 999 911 320 40. The third one appears to be the glove box rubber gasket 944 552 035 00.
Forth photo shows a bracket, I seem to recall seeing that type around the radiator lower shroud.
Last photo - pipe clips for brake, fuel, vacuum pipe..?
Shifter 06-13-2013 12:50 PM
Here are my best guesses. Maybe some pictures with aspect may half idenitfy more?
#3 cover for the sunroof motor take this back, not what that is.
#4 bracket for afm?
#5 dme cover/panel 944 551 149 02
#6 headlight motor bracket 477 805 622 or 617 (for left or right)
#7 Brake sensor
#8 clips for hardlines, a/c or brake depending on diameter
VirginiaF1 06-13-2013 12:52 PM
Don't all (well, virtually all) Porsche oem parts have a 944.xxx.xxx part stamp ?
Johnny B 06-13-2013 02:04 PM
Thanks for feedback guys will check them out on PET in the am and see what I can find with your guidance and report back.
I wish life would be so simple then, no lots of parts don't have part no's and some even have mold no's which are similar but not actual part no's, very confusing.
Again thanks for the help everyone
Johnny B 06-14-2013 02:55 AM
Thanks for the info rhett never would have been able to guess either of those rubbers, much appreciated.
Bracket near the radiator is part no 477 971 881 B looks similar but I don't know if it is same one as there seems to be an extra hole see what you think.
Any idea on part no for the pipe clips as I am struggling to find it on PET
Thanks again
Johnny B 06-14-2013 03:05 AM
#4 bracket for afm?
#7 Brake sensor
Thanks Shifter, appreciate the help
# 4 what is afm??
# 944 551 149 02 comes up as foot support on PET and doesn't seem to match photo
#6 477 805 622 does seem to match the photo against PET, one on PET seems to have a bend in it and different holes?
# 7 agreed thanks
# 8 any idea on potential part no
jeffrsmith 06-14-2013 06:24 AM
The part in the last photo is the clip that holds the Auto Trans hard lines in place. There are two of them mounted on brackets that are held in place by cam cover bolts and one all the way back at the trans.
Part # - 999 511 121 40
Part number 3
Porsche 944 Oil Cooling Parts
Johnny B 06-14-2013 06:28 AM
Part number 3
Thanks I would have never spotted that on PET
mhariush 06-14-2013 10:52 AM
AFM is the Airflow Meter, but I don't think that's what it is. I just swapped the AFM on my car and it doesn't look familiar. But, I've heard there's two different versions of the bracket, is that correct? So I could be wrong :)
Johnny B 06-14-2013 02:31 PM
Thanks not sure about different brackets
wolds 06-17-2013 01:16 PM
#4 is a bracket for the rear fog light on an older 911. My 83SC has one.
Johnny B 06-17-2013 01:39 PM
Well spotted, agreed definitely looks like part no 911 631 125 02 Fastening angle for rear spotlight, thanks.
Another one down many more to go
