-   -   Need help with ID of part (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/755584-need-help-id-part.html)
NBTF 06-12-2013 10:29 AM
So I was looking under the dash and I noticed a plastic clip was broken that held a rod to a lever, I am assuming it is part of the a/c system. Need to know if/where I can find the part or is it part of a larger item that I would need to get. Thanks.
http://forums.pelicanparts.com/uploa...1371058138.jpg
mhariush 06-12-2013 11:04 AM
It's a little plastic heater clip that's missing. By the color of the plastic clip on top i'd change that too...
944 Heater Fix
Paul_Heery 06-12-2013 11:26 AM
Yep. A cheap and easy fix. If the bottom clip gives way completely, your heater will come on in the cabin at full.
I actually picked up those pieces at my local Porsche dealer. I was surprised that they had them.
NBTF 06-13-2013 02:41 PM
Thanks. Yeah the bottom one already broke and I managed to get the rod to sit just right in the remaining thread area of he clip.
JAXTURBO 06-13-2013 11:46 PM
That reminds me ... isnt there another similar set up on the passenger side also? I replaced my drivers side clips, but I need to check the other side as well.
