AFM #725
Gawernator's Avatar
2nd gear woes
Well, was driving home today in my ghetto'd out 944 and noticed the car strongly protesting shifting into 2nd gear above 3.5k or so RPM. Regular driving no issues, except recently I noticed a very slight noise and vibration shifting into 2nd gear, maybe once out of every 25 shifts. Today I tried to shift from first to second at 4.5k RPM and when I pull the shifter I got horrible sounds so I stopped trying to force it... synchro randomly died? The PO "said" he put in MT-90 but I think a change to my own MT-90 to be sure might help at least in the meantime...
Watchdog Armory Racing AFM #725 Thanks to my 2017 Sponsors: JPH Suspension | AXO | Armour Bodies | BELL Helmets | Braven | EVLUTION Nutrition | Forcefield Armor | FunTrackDayz | Galfer | Motion Pro | MOTUL | Matrix Racing Concepts | ODI Grips | OGIO | Shorai Inc. | SPEEDMOB | Vortex | Woodcraft | Wicked Audio
http://www.gawerracing.com
Old 06-10-2013, 12:11 AM
Proprietoristicly Refined
John_AZ's Avatar
Gawer,
IF you change the fluid, use a white (t-shirt) rag over the clean pail used to catch the fluid.
Look for silver slivers. If none found ---it may not be the transaxle.
I cannot go over your past 4,175 posts to find out if the PO changed the clutch.
It could be a bad TO bearing, broken spring in the clutch disc, the disc guide tube weld broke, the clutch fork, rod or bearings failed or ????
GL
J_AZ
1988 924S, 85,750K ..+ 1987 924S, 154K DD (+15K est. bad odo)
Old 06-10-2013, 05:48 AM
The newest of the noobs!
grendiers's Avatar
On daily driving, why are you shifting at such a high rpm? First gear is basically there to get the car moving.
1989 944 Turbo
2004 Jeep Wrangler Unlimited - Built!
1985 Saurer 6dm overland Swiss military truck/camper
Old 06-10-2013, 10:20 AM
AFM #725
Gawernator's Avatar
The clutch disc was replaced in 2011. And I was going down a hill and hey, maybe one out of every 5,000 shifts I can waste a little gas
John, I hope it's just the transmission LOL
Old 06-10-2013, 05:07 PM
Redline Racer
HondaDustR's Avatar
I don't remember the last time I shifted out of 1st below 4k rpm. Jk... kindof 1st is so short, you don't really get into a strong part of 2nd without winding it up a bit in 1st.
Will it go in if you wait for the rpm to come down before pushing the stick?
1987 silver 924S made it to 225k mi! Sent to the big garage in the sky
Old 06-10-2013, 05:10 PM
AFM #725
Gawernator's Avatar
Yes, it shifts pretty normally or with a rare minor noise at lower RPM's. I'm pretty certain my transmission is original..
Old 06-10-2013, 05:16 PM
Silver would indicate spalling or other wear of the gear teeth or ring and pinion.
The synchro rings are made out of brass and the wear particles would be very small.
Change your gear oil and send a sample to blacksone and see what they say about it.
Old 06-10-2013, 06:07 PM
AFM #725
Gawernator's Avatar
Drove around today and it shifted normally... wtf
Old 06-10-2013, 07:56 PM
AFM #725
Gawernator's Avatar
Update: Problem has pretty much completely disappeared, can't get ANY sounds or grinds out of 2nd gear. ?????????
Old 06-13-2013, 07:24 PM
