Rod Schneider's Avatar
Annoying Upshift Light
I've got an 87 944S, which has the upshift arrow on the face of the tach. Does anyone have a good way of disabling this annoying light? I've had the cluster apart, and it appears to be an LED or something, not an easily removable bulb.........
If there is something I could unplug, that would be great, otherwise I guess I'll just make a cover out of black tape.........
Rod Schneider
Ball Ground, GA
88 928S4, 87 Corvette,
88 Fiero GT, 16 Mustang EcoBoost
Old 06-12-2013, 07:31 AM
Proprietoristicly Refined
John_AZ's Avatar
I am only familiar with the 924S upshift light---connected to the Hall sensor on the odometer.
Does the 944S have a miles per gallon guage as well? If you have both, you may loose the MPG function if disconnected.
'87 924S Speedometer wires?
J_AZ
1988 924S, 85,750K ..+ 1987 924S, 154K DD (+15K est. bad odo)
Old 06-12-2013, 08:30 AM
No MPG gauge on this one. The 944 has a different cluster setup from the 924S, all the gauges are in one unit with no hall sensor on the speedo.........
Rod Schneider
Ball Ground, GA
Old 06-12-2013, 08:33 AM
FrenchToast's Avatar
MPG gauge on the 944 was only in '86 and earlier non-turbos. Ditched for subsequent years.
CASIS (shift light) is actually pretty sophisticated and changes when it illuminates. CASIS was also on the Carrera 3.2's of similar years as well I think. It runs through the DME.
I believe CASIS was ditched for 1989. You could get a cluster from an '89 and newer non-turbo. But then your mileage would be off. AND I don't know if a cluster from another year (or just with different lights and things) would work.
Take care,
Old 06-12-2013, 08:35 AM
Ornery Bastard
I've pulled these clusters a bunch of times. The bulbs in the back are easy to pull for all the indicator lights. Is the CASIS light different from the rest of the indicator bulbs?
Silver 1998 Volvo S70 T5 <- Daily (Anja)
Guards Red 1986 951 <- Seattle car (Gretchen)
White 1976 914 2.0 F.I. <- Prodigal car, traded away then brought back again (Lorelei)
Old 06-12-2013, 11:34 AM
It's been a while since I've had the cluster apart, but I don't think it's a simple matter of removing a light bulb. As I recall, it's buried in the tachometer, and may be an LED soldered to a circuit board........
Rod Schneider
Ball Ground, GA
Old 06-12-2013, 08:15 PM
AFM #725
Gawernator's Avatar
It's not an LED. I might have a photo of it in my thread on removing the cluster and repairing odometer.
Watchdog Armory Racing AFM #725 Thanks to my 2017 Sponsors: JPH Suspension | AXO | Armour Bodies | BELL Helmets | Braven | EVLUTION Nutrition | Forcefield Armor | FunTrackDayz | Galfer | Motion Pro | MOTUL | Matrix Racing Concepts | ODI Grips | OGIO | Shorai Inc. | SPEEDMOB | Vortex | Woodcraft | Wicked Audio
http://www.gawerracing.com
Old 06-12-2013, 08:38 PM
Volhv's Avatar
The Canadian cars don't have the CASIS arrow. The tach or cluster from one of those would be an easy fix. You can than keep the useless fuel consumption gauge.
1986 944 NA Sapphire Metallic
http://944porsche.blogspot.ca/
Old 06-12-2013, 08:44 PM
AFM #725
Gawernator's Avatar
I like the MPG gauge ;P
Old 06-12-2013, 09:00 PM
gtroth's Avatar
How long have you been driving it?
I stopped noticing it pretty early on, but yeah, it bugged me too in the beginning.
It's actually come in handy for me after a long day a couple of times, zone out and forget about 5th gear, it'll remind you.
1995 993C4 guards red
1988 944S alpine white
Old 06-13-2013, 06:27 PM
