Rain Got in 944 Turbo
Hey Guys,
Drove my new to me 951 to work the other day and it poured rain while I was in there. Didn't actually drive it in the rain. Today I was looking in the storage compartments under the hatch carpet behind the fenders and some towels in there were wet. No other signs of water anywhere. Carpets are all dry. Hatch drains are clear, latch drains appear to be intact. Car has no sunroof. I did find one of the rear side markers had a gasket that wasn't seated properly on the driver's side but I got water in both sides and the pass side marker light was fine. How could water get in there? Should I just not keep rags in those compartments? Looks like most of the water must have drained out. Any thoughts appreiciated. Thanks,
1987 951 Sunroof Delete |
Well....behind the fuel filler door there is a drain on the bottom, that when disconnected will let water into the rear storage area on the passenger side, but with a sunroof delete car the only other place I can think of is turn signals. They might need resealed. Since the car is new to you the water could have been in there for years. dry it out and use the good old hose test.
How rare are turbo sunroof delete cars? Quote:
86NA944 |
Non Compos Mentis
The towels were left there by the PO but I know they were dry when I was rooting around back there before the rain. Will do the hose test that's a good idea. So I'll have to pull the carpet to re-connect that drain hose if it's loose I assume? Quote:
WOW, really nice car. Also check around the tail lights. I have seen them leak after 25 years.
Toofah King Bad
My car gets wet there. . .coming from the hatch glass separating from the frame. Check along the top of the glass, if you can see dimples in the glass your frame is distorted.
» 1987 924S Turbo - Got Boost? « "DETERMINATION. Sometimes cars test us to make sure we're worthy. Fix it." - alfadoc |
That is a great looking car, want to sell it?
86NA944 |
![]() Thanks! I just got it but if I were offered enough I would consider it.
Holy crap that's a nice looking ride!!! how many miles do you have on that thing?
86 951 blk |
86k miles
