another round please
strupgolf's Avatar
Door lock question
Car: 1989 944 S2. When I put the key into the door to lock it, the knob goes down but then comes right back up. I can lock the pass. side door by just pushing down the knob and it stays. What's up with these door locks where I cant lock the car up. The manual does not seem to help, or maybe I'm missing something. Any thoughts?
Getting old is not for wimps.
Old 05-15-2013, 06:39 PM
PorscheChef's Avatar
Do you have power locks? I have an 87 951 with the same problem. I think it has something to do with the power locks. Sorry I don't have an answer, just wondering if it may be the same.
'87 951 Nile Green, '86 951 Black, '86 951 Sapphire Metallic, '87 944 Nautit Blue, '84 944 Black (sunroof delete) "Track Beast!," '87 944 Black (LSD, Konis) (wife's track car)
Old 05-15-2013, 06:52 PM
sjv sjv is offline
my 88 N/A has the same problem right side door locks both doors driver's side won't work
Old 05-16-2013, 02:24 PM
Phantoms's Avatar
I guess this is pretty common. The same exact thing happens on my 90 S2, as well as on my friend's 86 911.
1990 S2 Coupe
Old 05-16-2013, 02:46 PM
Shifter's Avatar
If the central lock computer thinks the drivers door is open, it won't allow the door to lock. What happens if you press the lock button on the center console? Key has to be in the on position for it to work.
Using the key on either door should lock or unlock both doors.
Last time I saw this, one of the signal wires had broken in the insulation at the door hinge. Ran a new wire, and the locks have been happy since.
Old 05-16-2013, 03:47 PM
I believe I read in my owners manual that the reason this was implemented was so that you could not accidentally lock your keys in your car. It forces you to use the key to get out of the drivers door...Page 12
Doors
To lock, unlock and open doors from the outside
All doors can be locked with the ignition key.
The passenger door can be locked without a key by first depressing the locking knob and then closing the door.
The driver's door can only be locked from the outside with the key. This precaution was taken to prevent locking the driver's door while the key is still inside the car.
Squeeze trigger in door handle to open door.
Old 05-17-2013, 08:46 AM
Correction, I miss read, sorry though it was a different scenario
Old 05-17-2013, 09:45 AM
Phantoms's Avatar
I have an update on this issue. While fixing my non-starting S2 due to an alarm malfunction I inadvertently solved my drivers side door lock woes. (Mine were exactly as described by the OP)
Long story short:
Battery box was leaking- Repaired it. Found that the Alarm Control Unit part # 928 637 104 05 was completely filled with water. This is located behind the DME unit in the passengers foot well. I swapped the ACU out for a fresh one from a wrecked 89' S2 Cabrio and my car started up like a charm. A few days later when I replaced fuse #8 that I had removed during my original alarm malfunction (controls central locking and alarm horn) my drivers side lock was working like new again.
I'm assuming that before the H20 completely destroyed my ACU it only mucked up a part to do with the drivers side door lock? Or maybe the part of the ACU controlling this lock gave out on its own before the water showed up? Regardless, at least now we have a possible idea for the root cause of this issue on the S2 at least. I'm not sure if earlier cars have the alarm control unit in the same spot.
1990 S2 Coupe
Old 07-21-2013, 08:12 AM
