-   -   I think my timing is all screwed up, what do I do? (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/75625-i-think-my-timing-all-screwed-up-what-do-i-do.html)
overkill 07-25-2002 02:11 PM
I think my timing is all screwed up. Before I worked on the car I had the notch on the cam gear facing up towards the notch on the rear gear housing. I mark on the belt with paint its position on the gear. When I was all done with the work I put the gear back in the same way it came out. I forgot the order of the spark plugs on my DIS CAP so I hooked them up to the best of my memory. I got to start the car and i wont start. I heard a ching noise. I go back to look at the mark on the belt and it moved about a quarter of a turn!!! What do I do now!!! Are my valves screwed? What???
AFJuvat 07-25-2002 04:06 PM
In Nomine dei Patria et Spiritus sainti.....
(shaking head, offering prayer to the gods)
Overkill, check your private messages.
repeat after me, "I will note of the position of things before I take them apart, even if I must take a picture to do so."
"I will always make sure I am positive of crank and cam position before I crank the engine>"
AFJuvat
wolfrpi 07-25-2002 04:44 PM
your valves are toast. maybe you want to send your car over to 944S Boyee's mechanic? He could probably put a down payment on a new 911 with the money you guys are paying him to fix your S's. Sell the damn car and get an 8-valve.
overkill 07-25-2002 04:56 PM
I like you WOLFRPI, you have attitude:) Anyway, think i'm going to get another engine,.... a 951 engine.
overkill 07-25-2002 04:58 PM
Mike I'll call you tomorrow and you can sing to me Amazing Grace:D
AFJuvat 07-25-2002 05:05 PM
By the time you modify your car to accept the turbo engine, you may as well go buy a 951.
Hey, I hope it is amazing grace. Better that than a funeral dirge for your head and bank account.
AFJuvat
ae1969 07-25-2002 06:19 PM
WOW..... I can't believe it.......... who else is going to toast their valves???!!!!!
This is getting to be rather silly.
Ok so one S and one regular NA are now toast this month......... who wants to volunteer their turbo.......... :)
oooppppss its another S that bites the dust ..... ouch
wolfrpi 07-25-2002 06:31 PM
try 3 S's
944S Boyee
Overkill
Sternn
SoCal Driver 07-25-2002 08:54 PM
After the very recent engine replacement I'm about two years away from a scheduled belt change. Still I'll pull the top cover and look things over every six months. Think I'm closer to replacing the cam and valves as they are a tickn'! Somewhere down the line I have to consider a transmission replacement or rebuild.
Next major event is bleeding all the brakes.
Minor event is replacing one of the u-joints on the steering link. Well I guess that could become major.
Britwrench 07-25-2002 11:00 PM
In between the waves of disbelief that anyone would;
1. Work on a complicated engine with no idea of what they were doing.
2. Not make any notes on how things were assembled.
3. Not have at least the engine part of the workshop manual.
There are some things that can be done.
First, remove the spark plugs, rotate the engine (with a socket on the crank pulley) until number 1 cylinder is on TDC (check the marks on the flywheel) and use a long screwdriver to make sure the piston is at the top of the stroke. Once you have made absolutely sure the crank is correctly positioned, check the cam pulley and see if the timing marks line up. If they do, the valves
are ok. Then do a compression test. The mark you made on the pulley and belt will not always line up as the belt runs at a different speed to the pulley. It's possible the noise you heard might be due to something being loose.
Otherwise, the cylinder head needs removing and lots of money spent.
DangerIsland 07-25-2002 11:09 PM
Is one crank really enough to waste a valve? I always thought there was a slim chance that very little damage would be done, and since he (in theory) barely got one rev out of it, is it screwed for sure? Just a thought, I could be way off.
overkill 07-25-2002 11:14 PM
There is nothing loose on the engine that could of made that noise. Also, the cam gear and the fly wheel are not going to line up because I pushed the car without the timing belt on the cam eagr. Basically I screwed myself over big time. I have a haynes manual with the factory manuals on my PC, I also have PET. This mistake is due to lack of experience and knowledge. I am just going to get the 951 engine. I know it will cost but it's somthing I wan to do. Plus it will give a reason to replace everything like hoses, belts, fuel ines and on. If my car does not run tomorrow then I will make plans to pull the engine and break it down. I wll learn off that engine. I will use what can be used and sell everything else. It will be fine.
Britwrench 07-25-2002 11:17 PM
If you rotated the crank with the cam belt off the valves will be bent.
I look forward to the 951 engine installation saga........
DangerIsland 07-25-2002 11:22 PM
Every single person that has asked about dropping a turbo into an NA/S/S2/etc. car has gotten the same response on any web board I've ever read.
It's not worth it.
You're going against common sense, and the experience of dozens of people by doing that. If you "want to be different" than I guess that's fine, just know that it's going to be a painful process.
I don't know your history, but if a timing belt change ends up in destroying a head, I don't want to think about what you're going to do when you try to install that turbo engine.
fletch944t 07-26-2002 04:29 AM
Valves
Sorry to hear about your misfortune. There is a chance that your valves are not bent, albeit a slim chance. I have known folks who have had their timing belts let go with the engine at speed and experienced no valve damage (I would have lost my house betting the would have experienced some damage). On the other hand, I've seen guys damage valves just turning the engine over. In 90% of the cases, anytime the engine gets out of time, there will be damage. However, your odds are a little better since you were only turning the engine over. Put everything back in time and try it again. Make sure you have the plug wires in the correct order. The firing order is 1-3-4-2. Looking at the distributor cap from the front of the car, the top right plug on the cap is #1, then clockwise from there 3-4-2.
Like many of the other folks who have chimed in, I don't think swapping to the 951 engine is a great idea. The logistics are pretty mind-boggling. However, if you are set on going that route, I'll provide you with as much technical assistance as I can.
And, if you do decide to go that route, I might be interested in purchasing your old head, regardless of valve damage (provided the head itself isn't damaged). Since it's an '87 944S I'm assuming it's a 16V head.
overkill 07-26-2002 06:39 AM
Ok, here is what i'm planning on doing,... I am going to to get rid of the engine no matter what. Whether it is good or bad. I am going to payoff all my debt first. Once I have all my debt paid off, I will have all the money in the world to do what ever I want with my car. Question,... What is so hard about turning a NS into a turbo except the fact that it costs alot? My chasis is the same as a 951 chasis, right? I know that I have to replace alot of components to accommodate the 951 engine. What is so hard about a 951 convert? When the time comes, i'll be able to do whatever I want so If it is that hard to do the convert then maybe I will puchase one but if I don't have to I wont. Let me know what is so bad about the convert.
overkill 07-26-2002 06:58 AM
Also, I am going to pull the engine out of the car and dismantle it. I want to clean it up and learn about it. After I am done with it I will sell it to anyone who wants it. I only has 85,000 miles on it. That way I can use the money either towards my new engine or use it to payoff debt. When it's time to build my new car I will knwo alot about it. I really want to build the other car. If I build it I will learn so much. Even If I do mess up, I will be able to afford it:D
944S Boyeee 07-26-2002 07:14 AM
I want to welcome everyone to......
"The 944S Positivity Club"
I love it!!! Overkill "may" have bent valves.....his reply, "it will be fine". That's the positive outlook we here at the "944S Positivity Club" look for.
944S Boyeee (me) has lucked out and found a mechanic who worked 10 years for the local Porsche dealership, is a certified Porsche mechanic AND he fixes Porsches "cause he loves these cars". He has quoted me the staggering amout of $300 to put my car back together. He is now a "backyard" mechanic who doesn't advertise his shop in the paper, phone book or anything. A rare, positive find for me!!!
Also - I think Overkill "may" have bent his valves because he made a minor mistake while setting his timing and I bent mine because a timing belt went. We here at the "944S Positivity Club" realize that if we had an 8-valve, a 16-valve or a 640 Valve car, that it wouldn't have made a rats axx difference.
Long live the S and long live positive people!!!
944S Boyeee (Timing belt failure - 8 bent exhaust valves - and the S head is still alive..........I must be the luckiest man alive!! :p )
overkill 07-26-2002 07:51 AM
944SBoyeee, ha ha ha. Dude, I just want my 951, that's all. I said from the very begining that I wanted to turbo charge. If your head is still alive then there is a good chance that mine is too. You never know, there might not be anything wrong with it what so ever but,... thats not going to keep me from my 951 engine. I think when I done learning off the "S" engine that I should be able to tackle a 951 convert. I have the resources,... the factory manuals, pet, haynes, and most importantly you guyz. It will be cool:) Hey 944SBoyeee, when I done with my "S" engine it will be up for sale:D
Britwrench 07-26-2002 08:18 AM
And yet again, a perfectly good 944 turns into a garden ornament.......................................... ..
