AFM #725
Gawernator's Avatar
POPS 83 wanted to see
Well, I think I'm finally ready enough to show some photos of the disaster. Lol.
There's a bit of explaining to be had for each photo... I also had other things fixed while I have been undergoing this process, such as the nice hole my Dad's wife decided to put through the rear fascia by opening the door to a Ford Expedition while I was backing up....
Watchdog Armory Racing AFM #725 Thanks to my 2017 Sponsors: JPH Suspension | AXO | Armour Bodies | BELL Helmets | Braven | EVLUTION Nutrition | Forcefield Armor | FunTrackDayz | Galfer | Motion Pro | MOTUL | Matrix Racing Concepts | ODI Grips | OGIO | Shorai Inc. | SPEEDMOB | Vortex | Woodcraft | Wicked Audio
http://www.gawerracing.com
Old 06-15-2013, 01:01 PM
AFM #725
Gawernator's Avatar
New valence from Automotion $$$
Paint damage and minor dent from sideswipe...
Pablo welded in new metal where the hole was... good job
This rocker was a bit bent in from impact and had some damage, all fixed
Old 06-15-2013, 01:04 PM
AFM #725
Gawernator's Avatar
This fender I got off a guy from RL for $55 but Greyhound apparently mangled it on shipping... it had to be straightened and had some dents...
How should I re-connect this last bracket? Besides this the "new" fender is fully on.
Old 06-15-2013, 01:06 PM
AFM #725
Gawernator's Avatar
Lastly, there is a gap between the fender and the bumper.. I think the bracket slightly pulls it in (not sure) but it was also suggested to me to loosen the bumper bolts and it can be moved around?
I got this from RL user athens944 and he has been parting out the same car, lots of happy customers. There's pictures of the car and fender before removal, it's an NA with an NA bumper and this doesn't look like an S2 or 951 fender now does it?
Old 06-15-2013, 01:08 PM
1983 944 N/A
POPS 83 944's Avatar
Glad you are getting her back into shape!!! How are the brakes after you fixed them???
"To my family, the 944 is more than a new car. It is a new and true Porsche.
At Porsche, excellence is expected."
Dr. F. Porsche Stuttgart
Old 06-15-2013, 02:22 PM
AFM #725
Gawernator's Avatar
Brakes work great... I'm using ATE super blue fluid (still), Mintex brake pads which apparently are semi-metallic but I can't tell for sure, Zimmerman coated rotors. The only thing is at low speeds sometimes I hear a metallic scraping sounds like the pad is dragging on the rotor, goes away when I hit the brake pedal. I'm not sure if something is wrong or the pads are too thick or what. They were almost impossible to get in haha the fronts I had to hammer in the pads it was so tight. .... Stops quickly! lol, have not tested it on a "spirited" drive though... not looking to find more brake pad fade eek.
Also, when I took out the old pads one of the front pads slightly crumbled and broken pieces came off... wtf
Old 06-15-2013, 02:46 PM
1983 944 N/A
You didn't find a 931 nose panel?
Old 06-15-2013, 03:31 PM
944 addict
mytrplseven's Avatar
Send a message via AIM to mytrplseven
my '87 front calipers were a b---h to get on with new rotors and pads. I had to hammer the calipers down too. I suspect with the metal in the pads, you're dealing with more idling (non brake pressure) noise than if you used oem or soft pads. Are your rotors smooth or slotted/drilled?
When I looked at your pics, I thought it showed an exercise of parking at speed.
Body work looks good.
3 944's, 2 Boxsters and one Caman S, and now one 951 turbo. Really miss the Cayman.
Some people try to turn back their "odometers." Not me. I want people to know 'why' I look this way. I've traveled a long way and some of the roads weren't paved.
Old 06-15-2013, 03:40 PM
944 addict
my '87 front calipers were a b---h to get on with new rotors and pads. I had to hammer the calipers down too. I suspect with the metal in the pads, you're dealing with more idling (non brake pressure) noise than if you used oem or soft pads. When I looked at your pics, I thought it showed the results of parking at speed.
Old 06-15-2013, 03:43 PM
AFM #725
Gawernator's Avatar
Haha, thanks. So the random metallic pad noise is normal.. lol. POPS I did in fact get a good clean 931 panel with vents! It's in the garage! The body guy did the nose panel without me even asking... fine with me haha. Might as well sell it now I guess.
Old 06-15-2013, 03:54 PM
GreenWater's Avatar
Maybe no more "spirited" drives? At least you fix that car up after damaging it. haha.
Are you ready to share how you did it?
Looks like it's coming out nice. Just a camber problem and some paint.
www.Only944.com Porsche parts, Only better, Only944
87 944 N/A 165,000 miles
84 944
Saved by God, because I could not.
Old 06-15-2013, 08:48 PM
1983 944 N/A
Just in, I have found a picture taken of Gaw right before his brakes didn't stop his car (big brother is everywhere!)
Old 06-15-2013, 09:00 PM
AFM #725
Gawernator's Avatar
HAHA, yeah now! It's been a PITA getting this far lol. And the spirited drive isn't what did it, I was driving border-line maniac and was just fine. Coming home I was driving normally, my friend was car-sick LOL. Passed a bunch of "ricer hondas" and going down a hill brakes just... didn't really stop the car, haha. Hello mr. pole
Old 06-15-2013, 09:40 PM
That sure look like a heck of a way to treat a new paint job, but the progress that you are making now looks good.
Old 06-16-2013, 03:41 AM
AFM #725
Gawernator's Avatar
New, haha, it's a year old what are you talking about (just kidding)
Old 06-16-2013, 12:20 PM
Chunkerz's Avatar
Been there, done that. I hit a guardrail instead of a pole. Luckily for me I was only going 5-10mph and all I got was a nice crease in my front passenger fender...
Old 06-16-2013, 08:18 PM
AFM #725
Gawernator's Avatar
I was doing 35-40 I believe. :/ Along with pole included barbed wire fence, so... it managed to scrape most panels which is why I'm basically re-painting everything..
Old 06-17-2013, 01:07 AM
