951 turbo head on 86 944 NA?
I'm planning to install a 951 cylinder head to a 1986 944 NA. Any comment about this?
Old 06-18-2013, 12:14 PM
9FF 9FF is offline
9FF's Avatar
It will fit & function exactly the same as an na head but the hollow valves are more expensive and the ceramic liners can be troublesome.
If everything checks out its a straight swap.
Old 06-18-2013, 12:33 PM
nothing much different on the 951 head. 951 exhaust valves are sodium filled. i think intake valve is a smidge bigger.
nothing that'd affect performance significantly.
if u just got a good deal on a replacement cylinder head..sure why not
Do you think the ceramics gonna be a problem since it doesn't take that much beating (heat/pressure) compared to the turbo?
Old 06-18-2013, 04:55 PM
What about the valve spring? Will it be compatible with NA camshaft?
Old 06-18-2013, 04:56 PM
9FF 9FF is offline
9FF's Avatar
Valves spring are fine. Ceramic coating only becomes a problem if its not all there, chipped, cracked, etc. otherwise you're good.
Old 06-18-2013, 05:01 PM
So what's gonna happen if ceramic coating's cracked/chipped? Will it be a problem in terms of engine performance?
Old 06-18-2013, 05:49 PM
9FF 9FF is offline
9FF's Avatar
Quote de 9FF
Check the exhaust coating to see its all there and not degraded. Its not really a performance issue, its simply if that coating is failing there is no easy way to fix it whereas on the Na head you don't have that problem. Suppose in extreme case loose bits could end up in the chamber and cause damage but I would think that unlikely due to the gases going the other way.
Old 06-19-2013, 04:37 AM
Thanks. I'll try installing it and keep you posted about this. Maybe i'll add some pictures on this posting.
Old 06-19-2013, 08:46 AM
