Alternator belt
Do I have to remove the air box to get to the top bolt on the alternator to tighten the belt, or can it be done completely from below.
1978 924 The Grey Ghost - 18,000 miles and counting 1987 944 Black Betty - Bringing back from years of abuse |
AFM #725
I remember removing the airbox, it's simpler sometimes to just move stuff out of the way instead of struggling with wrench acrobatics lol
Watchdog Armory Racing AFM #725 Thanks to my 2017 Sponsors: JPH Suspension | AXO | Armour Bodies | BELL Helmets | Braven | EVLUTION Nutrition | Forcefield Armor | FunTrackDayz | Galfer | Motion Pro | MOTUL | Matrix Racing Concepts | ODI Grips | OGIO | Shorai Inc. | SPEEDMOB | Vortex | Woodcraft | Wicked Audio http://www.gawerracing.com |
Andrew Gawers' Dad
It's done from below. No need to remove air box.
944 addict
Yeah, pull the airflow pan on the bottom and do it all from below.
3 944's, 2 Boxsters and one Caman S, and now one 951 turbo. Really miss the Cayman. Some people try to turn back their "odometers." Not me. I want people to know 'why' I look this way. I've traveled a long way and some of the roads weren't paved. |
Do I have to loosen the top nut from below.
On the 944, you adjust the belt with a turnbuckle, no need to loosen the top bolt.
Bruce P. 2011 Cayman Base, LSD, Sport Chrono. 1988 951 totaled and missed ![]() "You're the best I ever had" --JJ Cale |
if the pivot bolts are not loosened, there is a chance for the mounting points to break.
that goes for the turnbuckle and A/C compressor. if you have an A/C compressor, loosen both the front and rearbolts, as wellas the turnbuckle mounting bolts. adjust then torque to spechs. if no A/C , not sure.
87 951 all stock exc. cup II's /94 968 6-spd, lowered,17in. RUF Speedlines, M030 anti- sways/ 94 968 Tip, Cup II's, otherwise stock |
If no AC, no need to loosen alternator mounting bolt.
There is only one, and it allows the alternator to pivot freely.
1986 944 NA Sapphire Metallic http://944porsche.blogspot.ca/ |
944 addict
I've done this many times and IMHO if you want to use a "TIGHT" upper bolt on the alternator as a pivot, good luck. I know that there are cases where the upper bolt isn't as tight as would be per spec and the alternator can be adjusted with the turnbuckle. However, it has been my experience on this and many other cars, that all the bolts should be loosened slightly to allow adjustment and the re-tightenend to specs. I've been able to loosen the upper Alternator bolt from below to allow adjustment of the belt. With an A/C car, the bolts for the A/C compressor should be loosened since that's easier to get to and you don't have to touch the alternator.
mytrplseven is right. Failure to loosen mounting bolts will result in either, tensioning rod failure, or bolt failure. How many more times can I say failure.
![]() But.... I have a late alternator, with an factory ac delete bracket. This setup forms a clevis, therefore it should be a slip fit. If the mounting bolt is over torqued until the alternator can no longer pivot, what one is essentially doing is stressing the alternator ears/tabs, and bending them inward. While that might not necessarily be enough to cause a failure, it's still a poor practice. I've heard that early alternators are a bit tighter between the ears. Maybe that's what caused the phenomenon mytrplseven has observed.
So I do have to loosen the AC bolts which I can do from below. That makes sense.
