Chad T's Avatar
Tail Light Re-seal pics
Hey Guys,
Re-sealed my tail lights today. prior to doing it I was able to find a few threads but no pictures so I took some in case somebody wants to do this. Pretty simple.
Didn't take a picture of the bulb holder but it just has a big white knob that unscrews to loosen it. I just unplugged one of the connectors and was able to set them aside. Here is a pic of the lens. You can see 4 of the mounting studs. There are 2 more in the middle.
I let the car sit in the sun for a bit but it was a pretty hot day and the old sealer was soft. Remembered about the bag of nitrile gloves I bought right after I got the goo all over my hands.
Used a plastic scraper to get most of it then finished it off with some wd 40. I tried laquer thinner but it went through the paint. Cleaned the sealing surfaces with rubbing alchohol before installing the new sealer.
I just sat the lens in my lap to install the butyl tape. From what I could find searching the net this is the stuff to use and it worked perfectly. 5/16 butyl tape from napa. I just described it to the guy at the counter and he knew exacltly what it was.
I started and ended on the bottom towards the center of the car. It smashes together pretty well and was easy to work with. What I did was set it in place gently with my fingers. Then I put the paper backing back over it and smoothed it out and smashed it firmly onto the tail light lens. You need to have it stuck pretty good before you try to bend it around the corners.
Installation is the reverse of removal. I just tightened it down gradually and evenly. With it being a hot day it oozed into place without too much effort.
I did this because I found out the water I was getting in the under hatch compartments was coming from the tail lights. Took a drive and seems to be less fumes coming in the cabin as well.
I would encourage anyone to do this as a maintenece item. Mine were obviously letting lots of water, air, dirt and fumes in the car. Not a bad little 1/2 hour job.
1987 951 Sunroof Delete
Old 06-20-2013, 07:09 PM
SLED GUITARIST
Dan Himan's Avatar
A bad hatch seal and/or key body seal will suck in exhaust fumes.
1988 944S Guards Red---Hers FRWilks Chip, MSD Blaster 2
1987 944S Blue Diamond Mine Crankscapper, MSD Blaster 2 Coil, Weltmeister Race chip, Sports pack. Hit by a sleeping driver at 2pm, soon to be the Black and Tan
1985 944na Gray---His Eibach Gound Control Struts/Koni Rear, Throttle Response cam. SOLD
Old 06-20-2013, 07:33 PM
944 addict
mytrplseven's Avatar
Send a message via AIM to mytrplseven
Good post. BTW, Goop would have taken off the sticky stuff and not affected the paint.
3 944's, 2 Boxsters and one Caman S, and now one 951 turbo. Really miss the Cayman.
Some people try to turn back their "odometers." Not me. I want people to know 'why' I look this way. I've traveled a long way and some of the roads weren't paved.
Old 06-21-2013, 11:00 AM
