-   -   Adding Turbo Side Skirts to 84 (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/757257-adding-turbo-side-skirts-84-a.html)
samevansjr 06-21-2013 02:10 PM
I'm adding the oem turbo side skirts to my 84 944. Has anyone done this? If so how hard and was it a pain to do? Does anyone have pics on how they are installed to the car?
Racerbvd 06-21-2013 02:48 PM
You don't paint them..
9FF 06-21-2013 03:48 PM
They will fit the body but I don't know if the 84 has the studs to mount them.
Basically the skirts have slots and holes that fit over metal studs welded to the underside of the floor. There are also a couple of brackets up front that you will need from the 951.
If the studs are there its quite simple to fit, otherwise you will have to weld in some studs or improvise another method.
