Driver
Soda blasting results
Hello all,
My new rule with this car is that anything that comes out gets worked over before it goes back. No putting anything dirty back in/on the car.
Since my exhaust system was out now would be a good time to clean everything. Sent the parts that didn't break, and I will be re-using, to a local soda blaster and I think the results are impressive.
Planned on painting this with high temp pain today but it is raining so that is a project for another time, till then I'll keep it warm and dry in my basement.
GHEN
'87 944
Old 11-17-2013, 06:58 AM
I had some parts sand blasted then tried the duplicolor brand "flameproof" primer/paint combo from the FLAPS. A couple things I learned or at least got in trouble with on this first experience with real painting:
I would recommend putting primer on it asap - perhaps brushable, but I don't know. rust shows up pretty fast and although rustoleum says its for use on "lightly rusted" metal, I don't know how much that is trustworthy.
also a user recommended to me to bake it first before cooling it, then immediately painting - I'd recommend that - no water, no rust.
the results of my "flameproof" paint application - per instructions? multiple coats of primer, black paint after, baking per instructions : about 20% of the piece was chipped. happened in the last bake cycle. I am not going to repeat the process with new paint - such a time sink.
if you absolutely must store it, I'd recommend leaving it uncovered and in a dry area. I had a piece wrapped up for one day and it got rust. It is awful to see the rust spots show up after a good blasting.
87 944 NA
Old 11-17-2013, 08:39 AM
AFM #725
Gawernator's Avatar
I sprayed my pipe with VHT flameproof ceramic paint and it went on fast and works great
Old 11-17-2013, 10:33 AM
Driver
Thanks guys, the day cleared so I hot water rinsed it and applied a heat gun then sprayed it with high temp rust-o-leum. I will keep the board posted with results.
GHEN
'87 944
Old 11-17-2013, 10:52 AM
Patrick
pfarah's Avatar
GHEN,
I'm 100% on board with your reasoning. I too clean all components and hardware whenever anything comes off the car for servicing. It helps find where the leaks actually come from!!
1984 944 NA, constant tinkering
1983 "Beastie" - Safari Build
Old 11-17-2013, 05:56 PM
Patrick
pfarah's Avatar
GHEN,
Old 11-17-2013, 05:57 PM
callmethewander's Avatar
Is there an echo in here?
1991 cabriolet (sold)
1989 S2
1988 S
1987 944 n/a (sold)
1987 944 factory yellow (junked )
Old 11-17-2013, 06:28 PM
Patrick
pfarah's Avatar
Yep... Yep... It appears that my tablet is becoming quite problematic lately. I'm on my laptop now now now now now.........
Old 11-18-2013, 05:57 PM
