Cannot Get Snap Rings in Groove on CV Joints
I can't for the life of me get the snap rings into the groove on the CV joint. I got the rings on the driveshaft. I used an impact socket to hammer the joint as far on the axle as I could, but it won't go on far enough to make the groove visible - it is just about flush. Same on both sides of the axle. For reference, I did switch all the hardware from inner to outer on the driver's side.
I've hammered away at the rings to see if I could bang them in, but no luck. There is a great video online of Van Svenson doing it online for his 914, which I can't replicate.
Seems to me the issue might be with the concave washer that provides the tension to the snap ring. The washer that came with the kit was not splined, and was slightly too large - it didn't catch on the lip as it should. So I reused the old one, but I'm wondering if the new snap ring was thicker, and the included concave washer was thinner, they were supposed to work together ?
Bruce
2002 C4S 105kmiles
Boston MA
Old 06-03-2013, 11:33 AM
Dave Colangelo's Avatar
I had this same issue, and also reused my old washers. I just hammered it down until the grove was exposed enough to get the ring on. Im not sure this is right but I have put 3K on the car since then with out an issues.
Regards
Dave
'78 911SC Targa (Back In Action!)
'00 996 Carrera (New kid on the block)
'87 944 (college DD - SOLD)
'88 924s (high school DD - Gone to a better home)
Old 06-03-2013, 01:51 PM
Good to know I'm not the only one who found the problem. I've raised it with the PP Technical Staff. Anyone else?
You must have hammered really damn hard on the joint? I've been beating pretty hard on the end (with the impact socket to distribute the load) and couldn't get it far enough in.
2002 C4S 105kmiles
Boston MA
Old 06-03-2013, 01:53 PM
Anyone else have this issue before?
2002 C4S 105kmiles
Boston MA
Old 06-04-2013, 02:54 PM
AKCJ's Avatar
I did mine about 2 years ago but didn't have the snap ring problem. I only did half of them while my 13 year old nephew did the other half (he finished ahead of me).
Red 83 944
Old 06-04-2013, 03:36 PM
Oh man! if a 13 year old can do it....
2002 C4S 105kmiles
Boston MA
Old 06-04-2013, 04:28 PM
Mike_944's Avatar
take a large socket and put it on the end and hammer it! worked for me
Old 06-04-2013, 09:48 PM
Mike - That's good to know. Maybe I need a bigger hammer !
I jest, but I think I may change my workbench & vise setup - there is some flex in the table that may be taking the punch out of my hammering.
2002 C4S 105kmiles
Boston MA
Old 06-05-2013, 08:05 AM
1983 944 N/A
POPS 83 944's Avatar
Is that the same clip that was on there before disassemble? My axle has a different style clips.
"To my family, the 944 is more than a new car. It is a new and true Porsche.
At Porsche, excellence is expected."
Dr. F. Porsche Stuttgart
Old 06-05-2013, 04:47 PM
Toofah King Bad
Rasta Monsta's Avatar
Use an impact socket that fits over the axle and rests on the inner race. Get your b-est fh and beat the fwayfarer out of it until it is properly seated.
» 1987 924S Turbo - Got Boost? «
"DETERMINATION. Sometimes cars test us to make sure we're worthy. Fix it." - alfadoc
Old 06-05-2013, 11:05 PM
Mike_944's Avatar
I wish I had those clips. Mine were a PITA!
Old 06-06-2013, 01:06 AM
It worked, thanks for the 'bigger hammer' advice guys. The trick was standing the axle on end to hammer down - got a lot more punch.
I massacred one of the 2 clamps for the inner boot. A little bit of redneck innovation to put a hose clamp on there. I imagine this will feel a bit like an unbalanced tire until I can get another clamp?
2002 C4S 105kmiles
Boston MA
Old 06-22-2013, 08:32 PM
Just use a zip tie.
1987 944T w/LS1
1981 (12/1980) 911SC
Old 06-25-2013, 09:27 AM
AKCJ's Avatar
Second the zip tie idea - that's what I did.
The boot fits tight and you may be able to get by with nothing?
Red 83 944
Old 06-25-2013, 02:53 PM
