Frenchy
Overheating, ugh gauge was bad
My 1987 924S temp gauge has been reading hot for some time. Replaced the radiator, thermo-switch, thermostat, fan relays ,hoses and sensor; and temp gauge still hit hot after a few minutes of driving. Finally used a infrared gun to measure the coolant temperature in the upper and lower hoses, both read perfect. Then pulled my temp gauge, UGH: Shortsville. Send the gauge to a shop in Hollywood, CA for a rebuild and it just came back. Went for a long mountain drive and yes, the gauge is reading right in the middle. Finally one more quirk corrected.
Take care
Frenchy
Old 12-28-2013, 08:35 PM
AFM #725
Gawernator's Avatar
Nice... it was the gauge all along
Watchdog Armory Racing AFM #725 Thanks to my 2017 Sponsors: JPH Suspension | AXO | Armour Bodies | BELL Helmets | Braven | EVLUTION Nutrition | Forcefield Armor | FunTrackDayz | Galfer | Motion Pro | MOTUL | Matrix Racing Concepts | ODI Grips | OGIO | Shorai Inc. | SPEEDMOB | Vortex | Woodcraft | Wicked Audio
http://www.gawerracing.com
Old 12-28-2013, 08:55 PM
Frenchy
Everyone, I forgot to post a couple things I noticed that indicate a faulty temp gauge:
* The gauge would waiver when I turned on my turn indicators
* Sometimes the gauge would sit at mid-temperature and then just jump to red in a few seconds
* Some days I could see the gauge actually go from cold to hot within just a few minutes of staring the car.
Also checked with our speedometer and gauge experts in Denver, they said the gauge could not be rebuilt, fixed or calibrated. Its pays to check with other locations.
Hopes this helps others.
Frenchy
Old 12-29-2013, 11:50 AM
1990 944S2
Send a message via Skype™ to ChrisRL
Frenchy, hello!
Care to pass me a message with the name of that shop? I think I might be having similar if not identical issues.
Thanks!
Chris
84 944 gold sold
90 944S2 black current DD
89 735il white fixing
89 GL1500 white restoring, 01 955i S3 black current DD
01 955i Sprint brg customizing, 89 955i Daytona gold restoring
Old 12-30-2013, 08:13 AM
monomoy4's Avatar
Frenchy
What were your upper/lower hoses reading at? I've been having overheating issues with mine as well and have been seeing 200+ on the upper.
1987 924S 5 Spd
1979 Jeep CJ7 3 Spd
Old 12-30-2013, 09:56 AM
Frenchy
temperature reading with infrared sensor
Everyone, after running car for approx. 15 minutes, lower hose from the radiator was showing about 147 degrees F and the upper hose was showing about 185 degrees F. Hope this helps.
Frenchy
Old 12-30-2013, 06:37 PM
