Can anyone help me with this control arm?
I just had a ball joint bolt failure on this control arm. I bought the car with these kind of arms on it. Don't know what kind they are or if I can get replacement parts. The ball joint has a through bolt with brass spacers. Does anyone know what they are or if I can get parts for them? I'd like to get a ball joint repair kit but dont know if that's a possiblity. Appreciate any info on them.
Old 06-27-2013, 08:41 PM
those are aluminum arms. There are kits out there for the ball joint repair. Rennbay has a relationship with Pelican, so I'm sure you can find them on the parts side. If not check out Rennbay.
Bruce P.
New to me 2011 Cayman Base, LSD, Sport Chrono.
1988 951 totaled and missed
"You're the best I ever had" --JJ Cale
Old 06-28-2013, 07:46 PM
campbelljj's Avatar
Rennbay
with all due respect to Pelican, call Travis at Rennbay. I just did both sides (always do both left and right) on my car. Travis (Rennbay) ball joint kit is super quality, with great service and always a phone call away if you need technical assistance.
Old 06-29-2013, 04:26 AM
ilikemy944's Avatar
Send a message via AIM to ilikemy944
Those do not look like factory control arms.
Brad Tompkins
Current: '86 951 Sunroof Delete - '89 951 - '83 944 Spec - '08 Cayenne Turbo
Past: '88 924S Track - '86 944 16v - '87 951 - '87 951 - '88 951S - '08 Cayman S - '87 944 Track - '93 968
Old 06-29-2013, 05:07 AM
Custom User Title
mikepellegrini's Avatar
They're not Lindsey and they're not Racer's Edge. I'm not sure who else fabricates 944 control arms. There's no name or number or anything on them?
I doubt you could use a standard rebuild kit. At the top left of your picture, if that's what's left of the ball joint, it's completely different than the normal 944 ball joint.
You might try sending full pictures (top and bottom) of your control arms to Lindsey and to Racer's Edge - they probably have an idea who their competition is in fabbing control arms. Maybe they could identify who fabbed yours.
I think unless you can find the person who made those and get a new ball joint from them, you're screwed. The only other alternative would be to find a machine shop to make a new ball joint for you special order. And that'd be big bucks.
A less expensive option might be junk control arms. If I did that, I'd definitely replace both, not just the side with the bad ball joint.
83 944 NA - Black on black
86 951 - Red
16 Ford Expedition
He who hesitates is lost.
Old 06-29-2013, 05:38 AM
9FF 9FF is offline
9FF's Avatar
That looks like a custom machined (billet) arm, never seen anything like it before. If it is it will be worth repairing and a machine shop should be able to fit new pins and joints. If there are no markings my guess is that its probably an early prototype of a Charlie arm.
If they are billet and not cast you have some nice arms there.
Old 06-29-2013, 05:59 AM
1988 944 2.5L 8-v NA 301k
VirginiaF1's Avatar
Welcome to forum Lars..
Those arms make the oem's look "not worthy".
Lucky you.. keep us posted on your repair efforts.
Cheers
'88 8v n/a 301k with 41k on current TBelt
M454 M533 M650 M425 M418
New Feb'13 Bridgestone Grid 019.. awesome.
Paid just $1,700 running & inspected.
Big RUSH Fan! Lic Plate = LIFESON
Old 06-29-2013, 11:39 AM
Thanks for your comments
They do seem like nice a-arms and I'd like to keep them. The ball itself seems like its just fine. The ball rotates in it's cavity and has a through bolt. The bolt is what sheared. I haven't found anyone who has ever seen one before. I'll keep trying.
Old 06-29-2013, 11:47 AM
9FF 9FF is offline
9FF's Avatar
..I haven't found anyone who has ever seen one before. I'll keep trying.
If you do find who makes them keep us posted.
I have the Charlie arms on one of my cars and imo nothing else comes close but they are nla. I would buy the ones you posted if they still made them for my other cars.
Old 06-29-2013, 12:04 PM
AFM #725
Gawernator's Avatar
Those just look sexy
Watchdog Armory Racing AFM #725 Thanks to my 2017 Sponsors: JPH Suspension | AXO | Armour Bodies | BELL Helmets | Braven | EVLUTION Nutrition | Forcefield Armor | FunTrackDayz | Galfer | Motion Pro | MOTUL | Matrix Racing Concepts | ODI Grips | OGIO | Shorai Inc. | SPEEDMOB | Vortex | Woodcraft | Wicked Audio
http://www.gawerracing.com
Old 06-29-2013, 12:09 PM
smokin_944's Avatar
Doesn't Racer's Edge still make control arms?
1984 - 944 Black / Wilwood/Brembo brakes / fresh M-474 suspension / Welt 250 lb fronts / 28 mm solid T-bars / M030 bars w Racer's Edge hardware/MSDS headers
Old 07-01-2013, 07:23 AM
9FF 9FF is offline
9FF's Avatar
Few aftermarket, Racers, Lindsey, etc. All are steel and all are expensive.
Old 07-01-2013, 11:19 AM
Control arms no longer available
Here's the scoop that I have been able to research. They were only made in a limited number by someone in the northeast. They are no longer available for good reason-while the arm itself is quite strong, the design called for a rather long pin and they were prone to shearing. That's what happened to me and it wasn't fun ended up in the tire wall. So I'll be replacing mine with stock arms can't find/afford charlie arms right now with my other expenses for my repairs. So looks are often deceiving.
Old 07-04-2013, 07:43 PM
9FF 9FF is offline
9FF's Avatar
imo those forged arms are still worth saving and a good machine shop can machine & fit a standard length pin & spherical joint so the problem doesn't arrise again.
The longer pin was probably put in there to correct the geometry of a very low car while keeping the arms parallel to the ground like they should be.
If you spend a few hundred $'s fixing those you will have extremely strong and light arms that wouldn't fracture like the stock arms if you do have an off. FYI last time I saw a set of Charlie arms change hands they went for over $2k used.
Old 07-05-2013, 10:06 AM
