majorcultfigure's Avatar
cv joint issue
I've had all 6 bolts shear off from the inner driver's side cv joint. Is it difficult to remove the receiver plate from the side of the transaxle to make it easier to drill out the broken ends? What toils will I need. Ant suggestions welcome.
Old 07-29-2013, 11:56 AM
Proprietoristicly Refined
John_AZ's Avatar
back in 10-10-2010, (your last post)
1987 924S transmission issues
Answer---
The transaxle drive hub is held in by a single hex bolt-torque is 25Nm (18 ft lb).
Remove the bolt and the hub comes out.
Get a new seal and some of Ideola's locking bolts-
Ideola's Garage: Suspension Upgrades
J_AZ
1988 924S, 85,750K ..+ 1987 924S, 154K DD (+15K est. bad odo)
Old 07-29-2013, 03:26 PM
Back from Beyond
All 6?! Wow. I wouldn't even bother drilling that flange/receiver. Just get a good used one. And new bolts, as His Lordship suggested ;>)
Old 07-29-2013, 06:33 PM
I had the same thing happen, only took about 1/2 hr with a drill predd and easy-out to remove them
Old 07-30-2013, 06:37 AM
That's once I removed the hub of course which was no biggy
Old 07-30-2013, 06:39 AM
John_AZ's Avatar
Slam,
You are welcome to visit my home anytime
J_AZ
(OP may take another 2 years to reply)
Old 07-30-2013, 10:40 AM
AFM #725
Gawernator's Avatar
Hail!
Old 07-30-2013, 12:52 PM
Back from Beyond
Yes! Perfect! I'll bring my favorite tools and some beer...
And a few hubs to drill?
Old 07-30-2013, 07:37 PM
