Fuel, Idle, Death
Hi All,
I am trying to get my car on the road, but am not able to get it on the road. It ran for about 8 miles perfectly fine, but then would not exceed 4k rpm. The car then refused to idle. I drained the whole gas tank, cleaned the screen in the gas tank, replaced the fuel pump, the fuel filter, and pulled and cleaned the injectors. I started it up tonight the car will fire immediately, but not hold an idle. If I give it the slightest throttle I can coax the car along till it will idle for a few minutes. If, however, I try to apply the throttle the car will immediately die. One thought is the fuel regulator might have gotten clogged or just has failed. Any input would be greatly appreciated. Thank you guys for allowing me to tap into your vast knowledge. Shawn |
AFM #725
Fuel pressure regulator sounds suspect to me. Would not exceed 4k RPM.... are you sure it's not a spark issue either like plugs, coil, etc
Watchdog Armory Racing AFM #725 Thanks to my 2017 Sponsors: JPH Suspension | AXO | Armour Bodies | BELL Helmets | Braven | EVLUTION Nutrition | Forcefield Armor | FunTrackDayz | Galfer | Motion Pro | MOTUL | Matrix Racing Concepts | ODI Grips | OGIO | Shorai Inc. | SPEEDMOB | Vortex | Woodcraft | Wicked Audio http://www.gawerracing.com |
What do the plugs look like?
1987 928S4 1992 968 cabrio 2009 957 Cayenne GTS |
944 addict
Have you checked the connectors of the tps and afm for corrosion and security? If one of the connectors isn't making good, solid connection, if could cause engine problems that come and go due to engine vibration. Also look for a vacuum line that may be coming apart of just old and cracked. This causes a myriad of issues with fuel regulators, AFM's and other stuff. Vacuum checks are easy and cheap and I'll be happy to show you if interested.
Good luck with this.
3 944's, 2 Boxsters and one Caman S, and now one 951 turbo. Really miss the Cayman. Some people try to turn back their "odometers." Not me. I want people to know 'why' I look this way. I've traveled a long way and some of the roads weren't paved. Last edited by mytrplseven; 06-27-2013 at 05:48 AM.. |
I suggest testing fuel pressure first then look at plugs and go from there.
Tom 1987 911 Targa 1987 944 Turbo 1976 911S 1973 Mustang Mach 1 351C |
I'd check the plugs right away, fuel pressure will not tell you if you have one leaking injector or one stuck one or something like that. They might tell you if you are destroying your engine running lean or just carbon fouling the rings and valves. You can also foul plugs so that when you do find the problem and fix it, the now-fouled plugs just confuse the issue.
The fuel pressure should be checked, and the damper could also be bad, blown and leaking fuel.
Thanks guys
I will pull the plugs and see if I am running lean. I will also replace the fuel regulator with a known good one. Checked vacuum lines tonight, everything looked good. I will clean the connections to the TPS and AFM. I will keep you posted on the outcome. Thanks again. |
Automotive Necromancer
2 bits
not likely but check air flow and exhaust flow restrictions. Double check vac lines. FPR, coil, There is a dual relay that powers the fuel pump and they can go flaky. check voltage at coil and Fuel pump, Which, I am hoping is good.
+1 on checking fuel pressure and plugs just to know.
There may be nothing quite as expensive as a cheap Porsche: Ruby Red 84 928S : White 87 924s 2.5L NA (Blinky) M44/07-43H10676 spoiler delete - 046/2B - Belts 9/12, Clutch and OC seals 8/08 andd Red 94 Del Sol: Please put your Make, Model and Year in Sig. Try not to break more than you fix. |
AFM #725
Lol might as well do a leak down and compression test while you have the plugs out.
New fuel regulator did the trick. Thanks guys
