944 addict
EPA compliance sticker
I have this sticker inside my door jamb and I'm wondering if anyone knows whether it means that the car is ok with California smog emissions standards as well.
3 944's, 2 Boxsters and one Caman S, and now one 951 turbo. Really miss the Cayman. Some people try to turn back their "odometers." Not me. I want people to know 'why' I look this way. I've traveled a long way and some of the roads weren't paved. |
All of the USA 944 cars were 50 state cars, so California emissions should not be a problem.
Good luck, George Beuselinck |
AFM #725
Then what is the "California Car" option?
944 addict
California "emissions" are ALWAYS "the problem" right, Gaw?
Interestingly the part number for the California equipped early 944's is 944 606 135 00, the same as the late California. Obviously the early federal cars have the single wire non-heated 944 606 133 00. |
AFM #725
Yes! I am very lucky to have not yet failed. California cars have the three-wire heated O2 sensor, this I know. If you haven't already, I upgraded to a new Bosch 'universal' three-wire heated oxygen sensor for like $30 off eBay, works great and I indeed pass smog! (assuming my cat converter is installed
Watchdog Armory Racing AFM #725 Thanks to my 2017 Sponsors: JPH Suspension | AXO | Armour Bodies | BELL Helmets | Braven | EVLUTION Nutrition | Forcefield Armor | FunTrackDayz | Galfer | Motion Pro | MOTUL | Matrix Racing Concepts | ODI Grips | OGIO | Shorai Inc. | SPEEDMOB | Vortex | Woodcraft | Wicked Audio http://www.gawerracing.com |
944 addict
my new O2 sensor has 3 wires plug ('87 944 N/A) but don't think it's a California compatible sensor. Not sure what the part number is but it was proper replacment for this car. So basically having 3 wires doesn't make it a Caliornia compatible or "heated" sensor, right?
As long as your car is fully warmed up it will pass smog the same
AFM #725
Yeah as long as you drove around for 10-15 minutes, got the RPM's nice and high, and have a working O2 sensor and catalytic converter I think you'll be fine..
944 addict
I haven't decided to move back to California yet, as much as I'd like to, but if I do, I'm definitely taking my 944. So the emissions issue was a concern.
Today, I took her out or a real test ride after replacing the TPS with a new Bosch unit (staggering acceleration) and new NGK plugs w/indexing shims. When I laid the loud pedal to the floor, it really takes off. Now I'm really enjoying my baby. Don't know if the indexing of the plugs is effecting a noticeable difference, but I've read some really great info from old school motorcycle and car racers about improved fuel economy and minor hp increases.
