MAF Compatibility
Hiya guys,
Ive been offered an Autothority MAF set up (Air flow stuff and chips) for a very attractive price. The setup is about 6 months used - owner had it on an 86 951 - said hes getting rid of it because it makes the car idle rough and run cold.
The price is so good I really want to grab it... he said Autothority looked at it for him when he was having his troubles and concluded that it wasnt the MAF.
I already have Autothority Stage II chips installed - can I simply leave them in and attached all the MAF stuff or would this create a problem? I think this question is redundant but Id like to make sure.. I think the chips and bolt he offered me are the same as mine anyway.
Regardless, I dont see any problem taking it off of an 86 and putting it onto an 87... anything I should look out for? Anyone have problems with MAF's?
88 911 (Sold)
87 951 (Sold)
Old 08-21-2002, 04:55 PM
No problems that I know of. If the price is right then get it.
Old 08-21-2002, 05:24 PM
Andyrew's Avatar
I think you should check with AA on the MAF chips. They have chips for every situation. The AA II chips were specifically setup to run on a stock car at 15psi boost. They have a tendancey to go lean in certain RPM levels. With a MAF on the car it could be too lean. Also, If you're already running Stage II chips, don't expect a huge difference in power by moving to a MAF. You've already done the big jump going from 12psi to 15psi. If you were starting at stock configuration, there would be a big change. What you do get is quicker spool, awesome sound, and a bit better airflow.
I run AA II chips with a Huntley stage III MAF. I can run as much as 18psi with the MAF and the ARCII fuel controller. Maybe you can do the same with the AA MAF, I dont' know what it's set for.
I'm talking too much for a lurker, Just check on the chips. Don't want to go lean..
DanD
86 951*2
Old 08-21-2002, 05:39 PM
dan10101's Avatar
Woops, Son's account again.. It's me..
Old 08-21-2002, 05:41 PM
Thanks, at the price, I think Ill pick it up anyway - hell... I could sell it and make a profit. Anyway - Ill let you know how it turns out... my next project is the wastegate... I "think" it may be becoming sticky... but thats a "I heard it from this guys who says... " routine.
88 911 (Sold)
87 951 (Sold)
Old 08-21-2002, 08:27 PM
