944 968 swap question
Just finished installing this swap. 968 engine in a 944 car.
944s2 bellhousing , clutch , pp, ring gear on the outside, installed the 944 starter and it just spins, ( no ring gear contact) started bench checks ok. ANY HELP?
PORSCHE, BMW, PREPARATION, MAINTINENCE, CONSTUCTION Cell # 707 775 7682 jjarvisautosports@yahoo.com |
The 968 starter is different from the 944 starter. You need part # 944.604.X.M14 sold here on PP. You could price a used one on ebay. The one for a clutch is different than one for an auto trans.
Cheers, Larry
Retired USAF and Civil Service, 1985.5 NA Graphite Metallic, A never ending work in progress, 1992 968 Horizon Blue Cab "New Toy"
The real 968 part number is 944.604.104.00 for the manual car. You can find remanufactured starters for less than $200 if you search. The $254 price on Pelican seems high
Tim '95 968 (Daily Driver) '87 944LS (track beast) |
tropicdawg
swap
I am doing the same swap.
seems like you would use 944s starter with s2 flywheel etc.not a 968 starter. maybe your solenoid is not good on starter.. |
tropicdawg
Hey Toy Store 968 into 944S
I am trying to figer out the wiring situation .. from what i understand only a few things have to be done on S car . e.g. green wire on ICM is cut and spliced together as it's not used.
where the confusion lies for me is on the DME ... I am doing a swap putting 968 engine in a 87 944S... one guy says all you do is get pin 7 powered by key on. The connectors are different. How do get the air to work? Any input would be appreciated.. I am also looking for links to wiring diagrams |
