-   -   rear hatch doesn't open with the key (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/763166-rear-hatch-doesnt-open-key.html)
arista 07-28-2013 06:35 AM
I have a 1989 944 S2 that the rear hatch only opens from the button in the car but not when you are outside and use the key. The key turns freely but does not unlock the hatch.
Any ideas of what to look for?
thanks,
968 GUY 07-28-2013 08:55 AM
check the microswitch at the lock for proper adjustment or if it needs replacement.
mytrplseven 07-28-2013 09:06 AM
If you pull back the carpet and look at the mechanism while you're operating it with the key, you'll quickly see what's not happening.
arista 07-28-2013 11:04 AM
thanks for the info. i went to the micro switch and it is clicking but it is not sending out any power. there are three wires. one has juice all the time. the other two don't get anything when i turn the key. probably the micro switch.
any help on where i can get that switch?
87m491 07-30-2013 08:15 AM
I think I saw the interior switch here maybe they have the micro switch as well? If not, it is avail on line. In the same vein, my micro switch works fine but I do not have 12 V into the switch from the body harness. Any ideas on where to check for a bad feed?
