PorscheChef's Avatar
Unhappy Strange Clutch Issue...
Long story short- '87 n/a, cracked cylinder, so I replaced the engine. The clutch on the original engine only had .3mm of wear so I took it off and put it right on the new engine. It was the type of clutch with the rubber center, but still good. I used the alignment tool and everything. Started the car, ran great...here's the issue- as the car runs in gear, randomly, the clutch seems to catch and start grinding. I quickly put it into neutral and it stops. When I put it back into gear it runs fine again then suddenly catches and sounds like it is grinding again. The clutch does have to be bled, but it has enough movement at the clutch fork to move through all of the gears. HELP!!!!
'87 951 Nile Green, '86 951 Black, '86 951 Sapphire Metallic, '87 944 Nautit Blue, '84 944 Black (sunroof delete) "Track Beast!," '87 944 Black (LSD, Konis) (wife's track car)
Old 08-23-2013, 07:43 PM
Back from Beyond
Did you change your TO bearing?
Old 08-23-2013, 11:24 PM
Thanks for your reply- I did'nt replace the TO bearing. It looked good, and it doesn't sound like bearing noise. It seems as though it is coming from the plate itself.
Old 08-24-2013, 08:34 AM
944 addict
mytrplseven's Avatar
Send a message via AIM to mytrplseven
Put you finger in the inspection hole and see if there's rubber dust or pieces of rubber in there. It could be that the disc looked ok but maybe being old, it just let go. That grinding could be the "get home tab" on the disc. Good luck.
3 944's, 2 Boxsters and one Caman S, and now one 951 turbo. Really miss the Cayman.
Some people try to turn back their "odometers." Not me. I want people to know 'why' I look this way. I've traveled a long way and some of the roads weren't paved.
Old 08-24-2013, 09:26 AM
Back from Beyond
Another test: park on a flat, level surface, place the car in 1st gear and leave the parking brake off. Hop out and get behind the car and rock it forward and back. If your clutch is on its limp tabs you'll hear them click each time they engage when the car changes direction.
Old 08-24-2013, 10:51 AM
